BIKELAND > FORUMS > ZX-14.com > Thread: zx14 oil pump leak NEW TOPIC NEW POLL POST REPLY
northernkaw
posted December 21, 2013 09:13 AM        Edited By: northernkaw on 21 Dec 2013 17:19
zx14 oil pump leak
checked a zx14 stock oil pump cover on an engine I was working on. I could fit fit a .003 feeler gauge between the cover and case.put the muzzy cover on and still had .0015 clearance. the machining on the case where the cover sits looks like its interupted and has steps in it. keep an eye on that when your building your motor. light filing helped to take the steps out but on my motor I think I will do a light cut on my mill.
1badzx12r
posted December 21, 2013 11:04 AM
gasket ?
northernkaw
posted December 21, 2013 02:22 PM
you put a gasket in there and your pump gear clearance will be to big
1badzx12r
posted December 21, 2013 04:53 PM
true. but i'd fix that with a metal shim
northernkaw
posted December 22, 2013 11:09 AM
you cant put a shim in to fix it the pump gear will eat it
posted December 22, 2013 11:49 AM        Edited By: Shane661 on 22 Dec 2013 19:50
thin coat of permatex or yamabond?
northernkaw
posted December 22, 2013 11:57 AM
that should work but its so close to the gear plus the clearance appears to be on the highside. this one measured .003
1badzx12r
posted December 22, 2013 05:02 PM        Edited By: 1badzx12r on 23 Dec 2013 01:10
if you say so ..
joseph702
posted December 27, 2013 07:45 PM
Yami bond is good shit
0.24374389648438 seconds processing time
