BIKELAND > FORUMS > ZX-14.com > Thread: Moisture or corrosion under gas cap 2012 ZX14R NEW TOPIC NEW POLL POST REPLY
Vanderhoffjs
posted August 11, 2013 08:00 PM
Having problem with corrosion under the gas cap of my 2012 ZX14R. I'm only running non-ethanol gas. It's like a white or gray build up around the locking mechanism on the gas cap. It's making it hard to open gas cap and I don't want to break key. I've cleaned it but it keeps coming back. Any recommendations? This is a newer bike with less than 3k miles. Any ideas?
John
John
2012 ZX14R
Neilp
posted August 12, 2013 01:59 AM
The only way to fix this is to remove the cap, pull it apart, be careful there are 5 small springs in there! regrease the mechanism & put it back together.
Alternatively you can replace the crap OEM cap with an aftermarket item.
Neil
zx12mark
posted August 12, 2013 09:19 PM
put some 3 and 1 oil on any moving parts...................your trouble is normal........next
0.23955488204956 seconds processing time
