BIKELAND > FORUMS > ZX-14.com > Thread: Question about Mags NEW TOPIC NEW POLL POST REPLY
capt10ed
posted March 24, 2013 07:09 AM
Question about Mags
Does anybody know if the mag wheels from a zx12 fit the 2012 zx14r?
I have Dymags on my 2004 zx12r and love what they did for the bike in terms of handling through less rotational weight
I am considering getting a 2012 14r and would like to fit the Dymags to it
and 204.5 in the mile.
zx12mark
posted March 24, 2013 09:03 AM        Edited By: zx12mark on 24 Mar 2013 20:08
I just put on a zx12r rear wheel on my 14r.It was the spare I use for drag racing so that`s the only time I will use it on the 14r. I used my vernier calipers to measure the clearance specs before I took the 14r oem set up off.The 12r sprocket hub is 6 bolt and the 14r is 5 bolt.The 12r sprocket hub will fit the 14r wheel. I put a 40 tooth sprocket on the 12r wheel.I had to modify the 14r speed senor rotor mounting holes (4) by dremel tool.Then I had to grind down the heads on the 4 mounting bolts .I had to use 2 small washers to space out the speed sensor pick up.Also the 12r brake rotor is smaller.You only have 2/3`s of the brake pad from the 14r touching the 12r`s rotor.
0.25943899154663 seconds processing time
