BIKELAND > FORUMS > ZX-14.com > Thread: D-Axis Rearsets w/CT Meg wont work!!! NEW TOPIC NEW POLL POST REPLY
Lsantana954
posted February 06, 2013 11:02 AM
Just a heads up for anyone looking at getting a set of these and running a brocks CT meg, and maybe any other type of megaphone exhaust, these d-axis rearsets will not clear the exhaust with the master cylinder mounted.
I have them for sale in the classified section.
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
venomous_zx
2012 14r - low and long-
posted February 06, 2013 03:39 PM
sorry to hear that. i was thinking about picking up a set of these. but the price was kinda scary. i wonder if these fit with the muzzle m10 that i run
sensei
Lsantana954
posted February 06, 2013 03:46 PM
is it a short meg style? yea im pretty much screwed out the money i spent to anodize the parts and then some..its my fault.
Youre better off just getting some vortex and call it a day.
'12 Gully Blue ZX14
'07 Acura TL-S
venomous_zx
posted February 06, 2013 04:12 PM        Edited By: venomous_zx on 7 Feb 2013 00:21
yea its their short megaphone. i like sato as well but pricey. id like to get rid of those bulky stockers. for some reason my right side peg is wearing out and tearing already. i only wear my tennis and or joe rocket boots when i ride. and i only have 3600 miles on my bike.
how much of a clearance issue is there? could you maybe put some sort of spacer?
sensei
Lsantana954
posted February 06, 2013 10:08 PM
i tried putting a couple of washer and mounting the muffler on the inside portion of its support bracket and no go. also the foot rest wont clear at its oem setting, you have to mount it the next holes up
'12 Gully Blue ZX14
'07 Acura TL-S
venomous_zx
posted February 07, 2013 05:51 AM
thanks for all the info. again sorry to hear you pay and custom them to have them not fit
sensei
Lsantana954
posted February 07, 2013 09:10 AM        Edited By: Lsantana954 on 7 Feb 2013 17:33
heres are some pictures. As you can see this is with the muffler mounted on the inside of the support bracket.
'12 Gully Blue ZX14
'07 Acura TL-S
Lsantana954
posted February 07, 2013 09:17 PM
well been on the phone with the tech from driven and think we mightve came up with a solution. it would be to modify the support bracket for the muffler and extended down, only issue with that is that you would have to either shave down the rear lower fairing or get rid of it all together.
dropped the bracket off at the machine shop and having them lower the mounting hole 3/8 of an inch, hope this does it.
'12 Gully Blue ZX14
'07 Acura TL-S
posted February 08, 2013 02:19 AM
With the vortex i had same issue
I made a new bracket, dimpled my meg so the rear part of brake arm had clearance and used the bottom cowl .
I removed the bottom cowl later as i have adjustable lowering links and like to adjust them and also made using my chain scrubber much easier without that 5 lb pos. Looks dumb on there with single exh imo anyway lol
Lsantana954
posted February 14, 2013 08:50 AM
took the mufler bracket to a machine shop and had them lower the mounting hole 3/8 of an inch and spaced out the rearsets using couple of thick washers and clearance issue is fixed.
'12 Gully Blue ZX14
'07 Acura TL-S
venomous_zx
posted February 14, 2013 10:00 AM
thats good that you got them to work after spending that hard earned money on them and on top of that getting them powder coated lets us know how they work out for you. may get a set.
sensei
epd345
posted August 29, 2013 05:08 PM
Santana, where did you get that gold hex head bolt for meg bracket? Looks good......
0.25762796401978 seconds processing time
