BIKELAND > FORUMS > ZX-14.com > Thread: Thinking about 2mil this winter NEW TOPIC NEW POLL POST REPLY
quikgix
posted November 25, 2012 08:44 AM
After 2 years of beating on my 07 14 and quite a few 170mph passes with nitrous on my stock piston and rod engine I think its time to split this bitch apart,what can I expect from 2 mil high compression pistons with stock cams? my best motor pass has been 8.59@156mph
1352cc 8.39@159mph on motor cant wait to spray this bitch
posted November 25, 2012 09:14 AM
That makes a 1417 ? Depending on what compression you use i'd say around 20 hp .. That should get you nicely into the 8.40s on motor ..
joseph702
posted November 25, 2012 09:59 AM
Going 2mm over on stock head ok ? I have heard that's the head don't flow to get gains out of it .
quikgix
posted November 25, 2012 11:37 AM
head is ported and also has APE valve springs
madnessracing
Vmax and Busa Beater
posted November 25, 2012 11:48 AM
I'm thinking about a 4mm stroke stock head ;-) Lol
Shorty's Performance
Team Madness Racing
kawpower
Mr kawasaki 2 you!
posted November 25, 2012 01:23 PM
Head cleanup, port match, 2mm pistons ,= 215 hp on pump gas more on race fuel.did that in 07.it does make quite a bit more torque too.
kawpower
Mr kawasaki 2 you!
smokinstorm
Old Drag Racer
posted November 25, 2012 01:34 PM
Now please don't yell and scream if I'm off base here but I thought cams were an integral part of a 2 mil motor. The cams are already too small supposedly for 1352cc and it'll just get worse with 86mm pistons. I've seen a 2 mil, cams, headwork 14 run around here and he's in a whole different class than our NA14 and we're not that slow at all. I watched him race another bike that ran a 5.53 on that particular pass and he patted the gas on him from the 330' on. If you add cams to the 2 mil engine with your riding skills and the way the bike is already set up I'd guess you'd run some 5.30's to 5.20's possibly in good air.
2009 Monster Edition ZX14
It's all stock I swear. Well...almost.
2005 Turbo Busa
2001 GSXR 1000
Looking for a 1985 GS1150E
edszx14
posted November 25, 2012 02:18 PM
I know of two guys running 2 mil motors and they are both a BEAST. You will love it. Good luck and can't wait to hear the results.
Ed
Audio
posted November 26, 2012 08:13 AM
I like my 2 mil would do it again
Audio
2008 ZX14 Old Gray CNC-1414 old new CNC ?
2012 ZX14R SE Green CNC-?
trganey
posted November 26, 2012 09:05 AM
We run a 2x4 with stock cams in a DB and it runs ok. 7.96 168mph @ Valdosta this spring.
06redzx14
posted November 26, 2012 01:17 PM
get a custom head gasket. either adams cut gasket or .030 cometic
joseph702
posted November 27, 2012 03:56 PM
Nice Iv been wandering about the cams thing , going bigger and after crank pistons boring it out and buying a home I can't afford cams. Thank u quick for bring this subject up.
0.22218990325928 seconds processing time
