BIKELAND > FORUMS > ZX-14.com > Thread: how to tune using wideband commander 2 and LCD 200 question NEW TOPIC NEW POLL POST REPLY
new14rider
posted November 19, 2012 03:54 PM
I was wondering if anyone has the PCV- Wideband 2 -LCD 200 setup and how you determine which a/f numbers in the logged data to make adjustments on. I know you have to look at your data after logging it in excel as Dynojet has no software. My question is should all of the a/f numbers at all gears, throttle positions, and rpms be the same??? Dynojet says have all numbers at 13.0 for best power. My problem is that when I look at my LCD 200 a/f on the bike as I ride it, it's all over the place. I idle at 12.2, low rpms are between 11.5 and 12.5. Whack the throttle and the a/f goes to 13.0 up to 14.5 and back down. I'm afraid I'll be chasing numbers forever. They also seem to be inconsistent and change with the throttle steady at a given rpm/gear. I have a brocks map installed with the CT megaphone and I feel as if the bike is rich. Doesn't bog, but not scary with what I've done to it. Very predictable and no real power surge in the mid range and some decel pop. Very rich. How do you pick which numbers to adjust in the map? Should I get a custom tune and map the top end richer for ram air????? I have never messed with a dyno map before. This seems overwhelming...... Brocks says their map is better than custom and I'll waste my money for less power.
Thanks!!
Seno
BANNED FOR LIFE!
posted November 19, 2012 08:28 PM
I am running the same setup, only thing you did not mention is the can bus cable. I have my unit setup as an autotune with a target AFR 13.2. As far as data logging goes, I don't bother, my primary use for the LCD is to load my nos map when I am out racing. I had a custom map made, have Brock's map, Ivan's map (which I think runs best, IMHO), and now just leave autotune on. As far as running, I think my bike runs perfect.... The best part is the set it and forget it, it will make adjustments for you.
new14rider
posted November 20, 2012 08:24 AM
Thanks. How do you setup autotune with the Wideband 2 and LCD200???? I thought you needed the seperate autotune module. I do have the can link I believe.
Thanks!
MotoCycho
posted November 20, 2012 09:47 AM
Thanks!
The folks at Dynojet can help you sort all this out over the phone. You should call them and get your money's worth.
toledoUPSguy
An old guy with a new toy
posted December 04, 2012 04:36 AM
WTF does that have to do with the question of the OP?
The man on top of the mountain didn't fall there.
2014 ZX14r in nuclear sunset orange and black
Seno
BANNED FOR LIFE!
posted December 04, 2012 04:54 AM        Edited By: Seno on 4 Dec 2012 12:54
Since that piece of shit decided to spam our boards with his overpriced cell phone jammers. If anyone is interested in a jammer at 1/4 of his price check this site out
http://www.epathchina.com/spy-devices-jammers-c-192_126.html
justoyz2
Justoyz Racing
posted December 08, 2012 11:53 PM
I have a simular setup, but I have the WB2 with digital guage:
-with my set up (terminator plug and a can to can cable)
-you must set the target a/f
-the application will not make adjustment as Dyno jet says... you must accept the changes in the SW.
-I have installed/used this combination on 6 bikes and it works well, until the weather changes, then you truly have to monitor your your a/f and accept the changes once or twice and you are good it will be minor changes.
Remember you must set the target A/F before it will start to populate data in the cells.... (this is with auto tune turned on of course
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
cliffrandall
posted December 21, 2012 04:46 PM        Edited By: cliffrandall on 22 Dec 2012 00:55
Auto-tune and a trigger map will not work together. Following lenghty discussions with the techs at DJ this past week, here is the set-up process......Use your AT to build a 13.2 A/F map or whatever A/F you want, then save that map and disconnect the AT. Now load your second n2o map for the juice trigger and you're good to go.
Cliff
0.22319912910461 seconds processing time
