BIKELAND > FORUMS > ZX-14.com > Thread: HOW TO GET THE FI LIGHT OFF AFTER INSTALLING 47MM TBS NEW TOPIC NEW POLL POST REPLY
BLK ICE
posted July 31, 2012 07:01 PM
HOW TO GET THE F.I. ERROR LIGHT OFF AFTER INSTALLING 47MM TBS?
BLK ICE
wrongway
posted July 31, 2012 07:16 PM
what code are you getting ?
Audio
posted July 31, 2012 07:17 PM        Edited By: Audio on 1 Aug 2012 03:18
I bet you still have a plug off, Thats what I d id plugged it in and it was gone.
Audio
2008 ZX14 Old Gray CNC-1414 old new CNC ?
2012 ZX14R SE Green CNC-?
posted July 31, 2012 07:23 PM
No FI code with 47's if properly set up. Check TPS.
BLK ICE
posted July 31, 2012 07:37 PM
thanks guys,
i will check the plugs, codes, and tps in the morning and report back.
BLK ICE
Y2KZX12R
CompetitionCNC.com
posted August 01, 2012 04:19 AM
+1
There shouldn't be any codes.
On the gen 1's 06-11
1) Set the final idle speed when the engine is fully warmed up.
2) Check the TPS output voltage with a digital Volt meter according to the manual. Back probe the connector with two very thin pieces of wire and make sure the output voltage is what the manual wants. It should be set correctly but its best to recheck it on the running bike.
3) Reset the power commander TPS settings in the PC software.
On the Gen 2 2012 just warm the engine, there's no idle adj.
Y2KZX12R
CompetitionCNC.com
BLK ICE
posted August 01, 2012 05:59 PM
I can't get passed fi code 32. I plan on taking it to a pro in the morning.
BLK ICE
posted August 02, 2012 04:31 AM
well, the local pro is on vaction, so i'm back the plan 1, Help!
GREYHOUNDMOSES
posted August 02, 2012 04:39 AM        Edited By: GREYHOUNDMOSES on 2 Aug 2012 12:40
Code 32-Subthrottle sensor malfunction, Wiring Open or short
Try checking the connector or connectors to the throttle bodies again.
RICH CRAFT 1
posted August 02, 2012 01:13 PM
that's the plug, center front of the throttle bodies.
Ken
Red 06 ZX14 RR
joseph702
posted August 03, 2012 05:15 PM
the senser needs to be slid on a lil turn it to get a spring feeling i think its like 180deg. i went thru this . if u need to call me i can explain it or tape it and send u the vid. pm me if u need number
quikgix
posted August 04, 2012 12:15 PM
after I installed my 47's my FI light came on at the track after a full pass. I went back to my pit shut it off and checked things out and couldnt find anything. I started it back up and the code was gone. Havent seen it since then.
1352cc 8.39@159mph on motor cant wait to spray this bitch
0.25142288208008 seconds processing time
