fullthrottlekaw
posted July 24, 2012 09:19 AM
air shifter bracket and vortex rear sets
just got my new vortex rear sets in the mail today and got them on the bike and now im noticing im going to have a problem mounting the air shifter ram to the shifter. i currently had a mr turbo horizontal mount on the bike but that bracket is not going to work and i question if the vertical mount is going to work either since the shifter is on the rear set now and not on the shaft like the stock one is. any cheap fixes or suggestions would be great!
thanks
fullthrottlekaw
posted July 25, 2012 08:18 AM
Hard to believe no one has this setup?
joel787
posted July 25, 2012 08:20 AM
i would like to know too...exact same problem happened to me, i had to switch back to stock
Seno
BANNED FOR LIFE!
posted July 25, 2012 11:35 AM
Why not just get a bracket or drill the vortex shift lever so you can attach the ram to it.... Like you would with the stock lever. Or mount the ram horizontally as opposed to vertically.... Personally I would try mounting the ram differently before I drilled up my new rearsets, or attach a bracket to the shifter (if it will work).
fullthrottlekaw
posted July 25, 2012 11:55 AM
That's what I wa trying to get away from was drilling into perfectly good rear sets to c if anyone else had tried anything I've been playing with it a little today so I guess I'll keep playing lol
fullthrottlekaw
posted July 25, 2012 06:26 PM
fullthrottlekaw
posted July 26, 2012 09:41 PM
does anyone know what exactly this piece is called? and where i can buy one without buy a whole entire kit? pretty sure i can make it work with this piece hooked up to the shifter rod. this kit was on zx12
