BIKELAND > FORUMS > ZX-14.com > Thread: Need some map help please NEW TOPIC NEW POLL POST REPLY
Seno
BANNED FOR LIFE!
posted June 27, 2012 12:57 PM
I had a custom map made for my bike about 2 months ago, was going to have a 2nd one made for NOS but was told by a few people that I need to add more fuel and that should be it. Agree or Disagree? Can someone explain how to do this? I do have the map file saved but when I go to map tools it only lets me add a pressure table, how do I add fuel?... Sorry for sounding like such a fucking noob....
Seno
BANNED FOR LIFE!
posted June 27, 2012 01:02 PM
MotoCycho
posted June 27, 2012 03:46 PM        Edited By: MotoCycho on 27 Jun 2012 23:48
You can manually edit the actual fuel tables, 1 cell or more at a time. You can select one or more cells and type the number you want or use the Page Up button to increase or Page Down button to decrease the fuel % on your computer's keyboard 1% at a time. Each number = 1% +/- from the ECU fuel mapping for that cell. So a -7 is 7% lean and a 27 would be 27% rich, over OEM fuel mapping. Don't forget to send your map to the bike and probably a good idea to save the map as a file as well so you have some revision history to fall back on in case it goes all wrong.
That help?
I assume you are doing a dry shot since you are adjusting fuel via your PC.
Use the Schnitz Racing Dry Nitrous Jetting and Recommendation Chart the on Schnitz web site to get you in the ball park based on your jetting and horsepower. Just add the percentage of fuel using the methods I explained above to your existing map based on the recommendations in the chart. Obviously you are enriching the fueling.
http://www.schnitzracing.com/technical_corner.htm
You should do some AFR logging for a bit to make sure you are fueling it enough for sure. I am using the DynoJet LCD-200 with my PCV and WB2.. it is not without it's challenges, but I still got a motor.. so far anyway.
Wheelie
Old Man
posted June 27, 2012 03:48 PM
Time for a Wego III.
wee
quikgix
posted June 27, 2012 04:58 PM        Edited By: quikgix on 28 Jun 2012 01:00
Go to a dyno! I added 30% to my custom motor map,then went to the dyno and fine tuned it. 11.8:1 AFR with spray. keep it safe
1352cc 8.39@159mph on motor cant wait to spray this bitch
Seno
BANNED FOR LIFE!
posted June 27, 2012 06:28 PM
Great, jsut found it. Thank you very much!
0.26365184783936 seconds processing time
