BIKELAND > FORUMS > ZX-14.com > Thread: LCD 200 wideband2 PCV not working on 2012 zx14r NEW TOPIC NEW POLL POST REPLY
new14rider
posted June 18, 2012 06:59 PM
Hey again!
Just hooked up the LCD200 to the Wideband2(jumper from WB2 to PCV and can terminator on WB2) WB2 red wire to headlight, both grounds to battery ground and o2 sensor connected. The LCD200 fires up fine with the bike but displays no info from PCV or WB2 (RPM guage is still and there are no readings for a/f) Only thing that seems to work is the power. Also, my Wideband 2 light is red and flickers. I don't know if that's normal? I do have a quick shifter installed on the number 1 input of the PCV if that matters.
Any thoughts???
Thanks....
almost_les
posted June 19, 2012 07:02 AM        Edited By: almost_les on 19 Jun 2012 15:13
you have to go in to the lcd settings and manually tell it which channels to display.
also, you should have three grounds. 1 black wire from the power commander 5, 1 black wire from the wb2, and then a black/white stripe wire from the wb2
0.23895597457886 seconds processing time
