SixSixoh6
posted April 27, 2012 12:10 PM
What a night...
Was riding for the past few weeks..doing just fine. Until....
Kicked the rear tire and made the whole bike buck sideways. Luckily no wreck.
BLK ICE
posted April 27, 2012 12:35 PM
I have seen that happen twice before. Both sets were purchased on ebay.
RICH CRAFT 1
posted April 27, 2012 01:01 PM
I have had that to happen before, the problem is, the bolt has threads all the way to the nut making it week. figure out about where your adjustment needs to be, go to the hardware store by case hardened bolts I think 8mm, get one that only has enough threads to work with what you have probably about a each and a half of threads the rest of the bolt should be smooth. This worked for me and I never had any more problems with that.
Ken
Red 06 ZX14 RR
Rob7R
More balls than brains.
posted April 27, 2012 01:09 PM
The bolts on my extensions look thicker than that... They definitely aren't adjusted out that far. Gonna keep my fingers crossed I don't have any similar problems. I've been riding her more than a year and 5,000 miles. Knock on wood.
Current bike- 07 ZX14 black with D&D cans, PC3, 43t rear sprocket, 6 inch extensions, roaring toys lowering links. Muzzy Bonneville Pro, TRE Velocity stacks, Puig DB windscreen, Sargent seat, Heli-risers, and throttlemeisters.
posted April 27, 2012 01:43 PM
We did that on Jesses bike and Roy ( Wrongway ) did it on his bike .. That is why i went with a new arm on my new bike ..I never had a problem before but i was a bit worried with the power this new bike makes to trust them bolts ..
Bad in Black
posted April 27, 2012 01:57 PM
If the axles tightened to spec torquewise I don't understand how that would happen. The bolts are just for adjusting right? Not meant to hold the power of the motor back? I know on my stretched, lowered, cammed and piped gsxr-1100 I have a similiar situation and have never had a prob. I know it doesn't have 14 power but it hits pretty hard. I also use a torque wrench tho and tighten that axle down to specs
Just not understanding why thats happening....
kaw-rick
posted April 27, 2012 02:24 PM
looks like adjuster block would of been better turned forward also? ive been 8.50s on extensions 170 mph. but i had good bolts.
BLK ICE
posted April 27, 2012 02:32 PM
cheap bolts
kawasakijockey
posted April 27, 2012 02:38 PM
Edited By: kawasakijockey on 27 Apr 2012 22:40
You gotta torque the axle nut to 90-95 ft lbs. Those botls are for adjusting not intended for containing the axle position. Why did you turn your axle around?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
LAB3
posted April 27, 2012 02:43 PM
quote: You gotta torque the axle nut to 90-95 ft lbs. Those botls are for adjusting not intended for containing the axle position. Why did you turn your axle around?
I agree.. I have several Snap On Torque wrenchs PM if interested.
Louis
MotoCycho
posted April 27, 2012 03:24 PM
Sometimes you have to flip the axle for clearance of the muffler on the right side. Had to do this on my buddy's 14. He is SWB tho.. pretty sure when you are stretched it's less of an issue??
SixSixoh6
posted April 27, 2012 04:08 PM
quote: looks like adjuster block would of been better turned forward also? ive been 8.50s on extensions 170 mph. but i had good bolts.
that's what i ended up doing, flipping the axle blocks around to have less bolt sticking out.
I flip the axle as to when you are tightening everything up it keeps your chain tight as to loosening it when the axle nut is on the other side. Something i've always picked up and have done on previous bikes
Extensions were purchased from a board member..soo im not sure where they're from. Look to be the same set i had on my 06 zx14..never had an issue then
SixSixoh6
posted April 27, 2012 04:16 PM
so now it looks like this
kaw-rick
posted April 27, 2012 04:52 PM
yeh thats better.
Big_T112
posted April 29, 2012 12:03 PM
replace bolts with grade 8 bolts. or drill and tap out to a larger size.
