BIKELAND > FORUMS > ZX-14.com > Thread: Lowering NEW TOPIC NEW POLL POST REPLY
conn-e-rot ninja
posted February 25, 2012 06:18 PM
Lowering
I'm going to get a set of soupy's links to lower the rear and slide the forks up for the front. My question is how far can I go safe is 1" the max or can I go further?
I'm at 64" running a busa spring and I have one of the low profile bolts like Shane used and I plan to cut the tab off. I do a lot of street riding and a bit of it's 2 up. I also hit the strip from time to time and I'm hoping to get in some land speed runs now that we have it in Ohio.
2007 zx14
BrucerZX14
posted February 25, 2012 06:28 PM
I have an 8 over McIntosh arm and Soupy's links. I'm at the max on the links. Guessing 3 inches lowered in the back. Pulled the fork tubes up about 2 inches. I ride on the street once and a while and didn't want to suck the tubes up anymore. Don't want to tkill my Brock's header.
posted February 25, 2012 06:35 PM
DO NOT slide the forks up more than 1" if you ride on the street. At 1" you can pull your front end down and make the nose touch the fender.My advice is you call OSR and get a modified oil pan.
You can lower the rear as much as you want, bascially until the tire touches the undertail.
conn-e-rot ninja
posted February 25, 2012 06:39 PM        Edited By: conn-e-rot ninja on 26 Feb 2012 02:40
Any issues with long distance rides with OSR pan? I ride 1400 miles to Sturgis every year. Can you go over 1" with the pan?
2007 zx14
NinjaNick
'08 ZX14 (Blue)
posted February 25, 2012 07:18 PM
I have the OSR pan and love it.
conn-e-rot ninja
posted February 25, 2012 07:20 PM
also I saw this thread anyone ever had any issues like that?
http://www.zxforums.com/forums/zx-14-forum/59501-zx14-cut-oil-pan-mod-smoke-pouring-out.html
2007 zx14
BrucerZX14
posted February 26, 2012 09:36 AM
I meant to say 1 inch. Fat fingered it.
conn-e-rot ninja
posted February 29, 2012 11:31 AM
So with a cut oil pan am I able to go 1 1/2" front and back or is 1" still the max?
2007 zx14
Newf14
2007 ZX1400
posted February 29, 2012 11:38 AM
I have 48000km on my ZX14 30000 + with the OSR pan and have no issues what so ever. I live in Newfoundland and have drove to the warf rat rally in Digby Nova Scotia distance is not a problem.
Newf14
conn-e-rot ninja
posted February 29, 2012 11:52 AM
thanks
2007 zx14
0.28186392784119 seconds processing time
