BIKELAND > FORUMS > ZX-14.com > Thread: texas mile info NEW TOPIC NEW POLL POST REPLY
redbarron2006
posted January 20, 2012 08:23 PM        Edited By: redbarron2006 on 21 Jan 2012 04:25
texas mile info
I am thinking about taking the 2012 and running at the mile in march, but i have a question, can you change the sprockets in factory stock? if not, how do I get around the 186 mph limiter? this thing should go damn near if not 200 in a mile dont you think?
redbarron2006
posted January 20, 2012 08:27 PM
here is a link to the rules if anyone wants to peak at it.
http://www.texasmile.net/pdf/TexasMile_RRTS_2012_2_Edition.pdf
Seno
BANNED FOR LIFE!
posted January 21, 2012 03:20 AM        Edited By: Seno on 21 Jan 2012 11:21
Assist...
Worlds Fastest Dad
230.157 MPH---- Mr.Turbo ZX14
posted February 11, 2012 07:44 PM
I can't wait to run the Texas Mile again.
How does the new location compare to the old one ?
posted February 11, 2012 07:50 PM
Yes you can change gears and still be stock .. I'd get the ECU reflashed and remove the top speed limiter also ..
Worlds Fastest Dad
posted February 11, 2012 08:06 PM
You will have to get a speedo healer, or do a gearbox mod to get around the 186, I did the healer because my 14 is an everyday drive and I wanted my speedo to work. If I had to make a guess on what the new 14 would do stock I would put it at about 192. It is much harder the most people think to break 200mph
Back in 07 when I was there, most zx14, busas, and zx12s were needing a 50-70 shot of nos to get in the 198-202 mph range.
The bone stock busas were running about 172-177 and the zx14s were running 174-181. I was really surprised by those numbers because I would have thought that they would of been mid 180's minimum. A couple of things to keep in mind the track temp that day was over 100 degrees with a slight head wind.
My first shake down pass was running 5 lbs of boost ( around 220hp) and I was at about 194 mph, it wasn't till I boosted up to 12 lbs till I broke the 230mph mark. I was soooo bummed out because I spun my back tire going in to 4th gear on that pass .. By spinning the tire at that speed with the asphalt temp at over 120 degrees shredded my back tire and I wasn't able to. Ale any more passes . Just knowing that I had most 300hp to use , no telling what speed we would of hit.
This time I go I am bringing a few sets of tires
posted February 11, 2012 08:13 PM
speedo healer will not work on the new zx14r .. You need to reflash the ECU ..
Worlds Fastest Dad
posted February 11, 2012 08:17 PM
My apologies, I have been out of the game for a few years with a nearly critical illness, so I am not up to date with the latest technology with the new 14
posted February 11, 2012 08:43 PM
No problem .. I hope you are feeling better .. I have been ill for about 8 mos myself ..
Worlds Fastest Dad
posted February 11, 2012 08:54 PM
Pm me with info if you want to talk
posted February 11, 2012 11:20 PM        Edited By: entropy on 12 Feb 2012 07:24
WFD,
we were rooting for you as Terry turned up the boost, disappointed when you shredded the tire. Has it really been since 2007 when you were there? Time flies
RB,
If you wanna run in March, better see pronto if there are any grid spaces left, registration has been open for some time, and they normally fill it fast.
Beeville is much like Goliad, although much bigger venue, but the track is similar, longer shut down. Some folks don't likea couple bumps in the track.
I ran 218 on NA Busa at Beeville in Oct into a headwind. Bumps in track weren't an issue for me.
Karl
posted February 11, 2012 11:23 PM        Edited By: entropy on 12 Feb 2012 07:25
Hey you Texas and nearby Texas folks, are any of you besides RB planning on running Texas in March on the ZX14R??? It would be cool to see if a stock bike can crack 200mph!
Karl
1badzx12r
posted February 13, 2012 02:02 PM        Edited By: 1badzx12r on 13 Feb 2012 22:05
I have an 06 Hayabusa that I built to break 200mph in the standing mile. Its been highly modified but its still street legal. I've went 201mph on it this past July. I went through the motor and made sure it wasn't hurt and redynoed it at 207hp with 119 torque. That's an all motor bike, no nitrous or turbo. Its one of the fastest all motor bikes in the state. I have put together a list of some of the mods that I've done to it. I'll try to find some pictures of it somewhere. Its all black and I have most of the original burgundy fairings in the attic. I don't have the fairings on it right now because I'm reworking the 24volt starting system. Let me know if you are interested and we can talk. I would really like an 08 or newer 1000cc sport bike with less than 10k miles on it. I want to build a liter bike with a turbo to race now. My bike has right around 9k miles. Its in great condition and it needs to go to someone who will ride her more.
World Wide ceramic wheel bearings
Metal valve stems
Stainless steel braided brake lines
EBC brake pads
Canadian Mike extended swingarm 2-6 over
Heavy duty DRZ -2 chain
Tiger tail--black
Galfer stealth rear rotor
Revolution Front rotors
Intergraded LED tail light
Muzzy sidewinder exhaust with baffle
Heavy duty clutch springs
Brocks clutch modification
High pressure oil pump gear
Fully adjustable lowering links
Adjustable rear sets --black
Chrome side stand for lowered motorcycles
Lovell triple tree with gauge openings
Electric fuel pressure gauge
Shorty levers--black
Cut and lowered factory tank--black
Walboro external fuel pump
Lowered racing seat as well as stock seat
24volt starting system with new batteries
Safety wired for track use and still street legal
Heavy duty valve springs--65 lbs
Gen 2 titanium valves
JE pistons 12.5-1 compression ratio 84mm 1397 motor
Ported and shaved head
Thinner head gasket to raise compression
Web stage 2 racing cams .395-.378
Dyno'd at 207hp at the wheel and 119 torque
Several different sprocket sizes front and rear
Safety lanyard installed
Power commander no longer used but comes with the bike-currently using ECU editor instead
Good condition Pilot Powers on front and rear
I'm sure that I forgot a few things but this is a good start.
Ryan Arnold
Race Director
The Texas Mile
little info that this cat did it with what a stock zx14r dyno's at
Worlds Fastest Dad
posted February 13, 2012 02:27 PM
Like I said .. It isn't easy to hit 200mph congrats on running 200+ on all motor
XXX
1badzx12r
posted February 13, 2012 02:31 PM        Edited By: 1badzx12r on 13 Feb 2012 22:33
i didn't do it .. i found the add on craiglist with the bike for sale.. and i said "mmmm" stock zx14r has or have dyno this much hp and tq from board members .. should be close
posted February 13, 2012 11:15 PM
Ryan ran his 201 at Loring, Maine 1.5mi event last year; it's way more difficult with the persistant head wind at Texas 1.0mi. (not a tit even at Loring)
With a lil tail wind stock motor Gen2 Busas & Zx14's have run just over 200 in the Mile. Gotta ride the piss out of it, but it can be done.
The extra hp of the ZX14R could certainly put it over 200 if the rider is experienced and the weath cooperates. Bring those big boys out!!!!!!!!!!!!!!!!!!!!!!!!
Karl
Worlds Fastest Dad
posted February 13, 2012 11:58 PM
How many passes can you get in on the Maine event ?
Is that track in better condition the the Texas mile ?
XXX
posted February 14, 2012 03:36 AM
Loring = 3-4-5 or so passes a depending on how fast you get back in line, hot lap sun pm.
300' x 14000' is in very, very good shape.
0.28556108474731 seconds processing time
