BIKELAND > FORUMS > ZX-14.com > Thread: Setup questions NEW TOPIC NEW POLL POST REPLY
fullthrottlekaw
posted January 18, 2012 10:49 PM
Setup questions
Should be receiving my Adams extended stock arm in the next week or so for my 08. In the process of looking for a new chain haven't quite decided how long I should go on it it will go to 9 over I was thinking about setting it at about 8 over my question is on a stock shock, stock motor with Brock's exhaust and pc3 would that be a correct length for a good hookup ik I can always shorten it up if it spins also I'm currently -1 in front stock back prob get a +3 in the rear?I'm about 220 suited and final question would a 150 link chain be long enough for that setup?
Thanks for any advice!
Newf14
2007 ZX1400
posted January 19, 2012 04:12 AM
I have mine set at 68-69 inches roughly I had the stock shock brocks exhaust pc3 -1 front +1 rear, and mine hooked 90% of the time and we have poor track conditions where I race. I say I am about your size as well. Not shur on the chain but I think it will be long enough..
Newf14
dakota9498
posted January 19, 2012 04:59 AM
150 will be plenty, mine sits almost 9 over and I had several links left over with the 150 I bought.. And just my opinion but, get a good chain, most of us run EK ZZZ. And as long as you are running a good tire you will have no problem hooking at that length. Your budget and preference guides your tire decision really, I run a Hook-Up and I love it, others don't like them at all. If you have money to burn a Michelin Pilot Power 1 is what all the Pro Street guys run.
Good luck and let us know how it turns out.
2008 ZX14
Seno
BANNED FOR LIFE!
posted January 19, 2012 05:26 AM
Good info, so the pilot power 1 has the most grip for a street legal tire?
fullthrottlekaw
posted January 19, 2012 05:43 AM        Edited By: fullthrottlekaw on 19 Jan 2012 13:43
i had a hook up on my gixxer 2 yrs ago the thing hooked every time with barely a burnout never used michelin before cant justify buying a 250 dollar tire that im gonna burn off anyways...for casual use at the strip imo you cant go wrong with the hook up. thanks for the info guys
u think +1 in the rear will be enough gear at my size?
thanks
dakota9498
posted January 19, 2012 05:54 AM
I agree on the Hook Up, I love mine, and I can't justify the price of a Power 1, just giving options.
And gearing is truly subjective. Some people like a lot of gear, some don't. It really depends on your riding style and what you are comforatable with. I run 16/43 and I really like it, but I am 170ish unsuited. If you decide to try more gear let me know, I have a brand new Vortex 46 tooth I would part with cheap. I bought it and never even installed it because I was comfortable with the 43.
2008 ZX14
dakota9498
posted January 19, 2012 05:56 AM
I am not sure about that, but like I said the Pro Street guys are hooking almost 500hp with it on the nitrous bikes and probably a lot more than that on the turbo bikes. But like I said, my personal preference is the Hook Up, it is a great bang for your buck. I can get those shipped for around $130, the cheapest I have seen a Pilot Power 1 is just under $200 on sale.
2008 ZX14
KAWITOM
My 12R gone but not forgotten
posted January 19, 2012 08:40 AM
Like Dakota said the ZZZ is an awesome doesn't stretch alot, it's the lightest oring chain with high tensile strength. I used the hook-up tire with my turbo busa and the u-soft on my zx12 those Shinko tires have worked great for me the only thing I think you have to be careful with the hook up is to not got low on tire pressure on like a 300 hp bike because the side wall is so soft, the Hook-up is great for track use but wouldn't recommend it for street use it won't last that long you can use the u-soft you'll get more wear time with only a little sacrifice of grip. The greatest thing is you can get shinko's delivered to your door for around 120's to 130's. The Michelin is a 200. plus tire that wears just as fast as the hook-up
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
DocsNinja
Backs and Bikes is what I do..
posted January 19, 2012 08:54 AM
Call Doug at spencercycles for a great price on the zzz chain and shinko tire ..Tell Doug smokinzx14 sent you ..
Docs Cycleworx home of Dr. Ryan Scarsella and SmokinZX14.
  Ignore this member    Click here to visit DocsNinja's homepage.
posted January 19, 2012 12:35 PM
I posted that from work .. Smokin ...
Wheelie
Old Man
posted January 19, 2012 12:42 PM
I think ama guys used it because it was lighter than a shinko, shinko has a wide contact patch.
wee
posted January 19, 2012 12:47 PM
As far as gearing, they are correct in above post. It's a personal preference.
I'm at about 66" (8") and I'm -1 +7 (16/48) and I love it. It's easy for me to make the bike dead consistant. Now if I was 2" shorter on wheelbase, it would be too much.
I also believe the lower gearing helps on Clutch wear because your not sliding the clutch nearly as long. That's just my $.02 though.
Ekzzz is the way to go. I haven't tightened mine in almost a year. It's still as snug as it was last time I tightened it.
If your not sure on gearing, try 16/44, that will put you in the middle of high/low. Then you will know which way to go.
Btw, I'm 215 suited as well.
dragbikercr
posted January 19, 2012 02:38 PM
I am roughly 8" over using 6"-9" extensions (welded into swingarm) stock shock, stock exhaust with slip ons, PC3, using EK DRZ 2 chain (non o-ring), 16/45 gearing, I am 230 suited. I am consistant 1.48's 60 foot. I tightened up the rear shock all the way on compression and rebound screws, doesnt hit the under side of tail section. I wish I would have gone 10"-12" over, I still dont think it would spin. Also I run nitrous for the "oh shit" factor, when using it I am at top of 6th gear through traps. When im not using nitrous im right at top of 5th (almost at redline) in 1/4 mile, its a perfect gear setup (16/45) for me.
KAWITOM
posted January 19, 2012 02:41 PM
What is nice about the shinko's is the fact you don't have to run as low tire pressure depending on hp level because of the fact it isn't a peaked tire like a regular street bike tire at 15 to 17 psi you get close to five inches or so of contact patch that is the main reason the shinko's are such a good tire and minimum amount of dimples in the tire means the tire grips better but I wouldn't be getting to aggressive in wet weather.
2012 ZX-14R SE
I BLEED GREEN
dragbikercr
posted January 19, 2012 02:45 PM
Like everyone else said 150 links, you will have plenty left over. Oh and I am also running the Shinko and love it, especially the price. Mine is strip only no street.
dakota9498
posted January 19, 2012 04:42 PM
I run my Hook Up on the street, lots of 170-180 mile days and it last as long as the U-Soft did.
2008 ZX14
kawasakijockey
posted January 19, 2012 05:29 PM
EK ZVX2 chain. Great chain for street/strip.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted January 19, 2012 07:25 PM
Kawasakijockey, what's better about that chain over the zzz?
joseph702
posted January 19, 2012 09:01 PM
dakota ill take the sproket how much
KAWITOM
posted January 20, 2012 04:18 AM        Edited By: KAWITOM on 20 Jan 2012 12:19
Both the ZVX2 and the ZZZ are both awesome chains about the same tensile strength, just the ZVX2 is a little cheaper and a little heavier, the ZZZ has little holes in every side plate that is where the weight reduction, every side plate X 150 links it's quite a difference. I think the ZZZ is about thirty dollars more. The tensile strength of ZZZ is 11,100 lbs on a 530 the ZVX2 10560 lbs on a 530.
2012 ZX-14R SE
I BLEED GREEN
posted January 20, 2012 04:26 AM
Thanks!
0.2801878452301 seconds processing time
