BIKELAND > FORUMS > ZX-14.com > Thread: Red loc-tite NEW TOPIC NEW POLL POST REPLY
darrylez1
posted January 13, 2012 02:05 PM
Red loc-tite
I used red loc-tite when I mounted my rotors on my BST's.My son now has my 07 and there is no way he's getting the BST's,will a hair dryer be hot enough to soften the loc-tite,I don't want to use a torch.
07 14 ,brock S-meg BST's,2012 14r BST's ceramic bearings,rear sets ,full Hindle Evo
Seno
BANNED FOR LIFE!
posted January 13, 2012 02:14 PM
Red is pretty strong, bit usually I am able to just take the bolts off without heat. Heat gun would probably work, not sure about a hair dryer... You have nothing to lose trying. Good Luck!
posted January 13, 2012 02:15 PM        Edited By: Shane661 on 13 Jan 2012 22:16
I would be VERY careful about any heat around those BST's.
posted January 13, 2012 02:22 PM
Info on BST's and heat:
http://www.brocksperformance.com/absolutefm/afmviewfaq.aspx?faqid=336
darrylez1
posted January 13, 2012 02:35 PM
Okay,I'll try a hot air plastic welder it has a digital stat that I can set the temp range off to 400 c.Shane what did you use for your rotor bolts,red,blue?
posted January 13, 2012 02:41 PM
Ive always used red and not had issues removing the bolts from my stock rims without heat. make sure you have a good Allen key. a small torch for soldering may heat the bolt without heating up the surrounding areas. something like this
http://www.thinkgeek.com/gadgets/tools/8868/
posted January 13, 2012 02:47 PM        Edited By: Shane661 on 13 Jan 2012 22:47
I use Loc-tite blue...but the Honda medium is red. You can't just go by the color if you don't know the manufacturer.
posted January 13, 2012 02:53 PM
good point
i use permatex
http://www.permatex.com/products/Automotive/thread_compounds/a_threadlockers.htm
kawpower
Mr kawasaki 2 you!
posted January 13, 2012 03:51 PM
a good soildering pen will do it.
Rook
posted January 13, 2012 05:24 PM
I was going to suggest that or heat an allen wrench with a torch and place it in the hex for a minute....
only if you have to.
I'd avoid putting heat directly on carbon fiber at all costs. Hot air would be the last thing I would try.
zx12mark
posted January 13, 2012 08:06 PM
yes you can loosen the lock tight with heat.i have to do it every so often on the universal joints on my axis bass drum pedals.i use a heat gun but i would use a pencil torch on the bolts only.it takes about 350 degrees to turn liquid but i would see if they will turn after 10 seconds or so.
joseph702
posted January 13, 2012 10:00 PM
Use butterfly gun the shock breaks it free.
0.2776210308075 seconds processing time
