BIKELAND > FORUMS > ZX-14.com > Thread: Spinning? since new arm installed NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted June 10, 2011 08:13 PM        Edited By: pazx14rider on 11 Jun 2011 04:16
Last year i was running +6in extenstions traction was never an issue. I have always run a Shinko Stealth. Ever since i got the bike to the track this year after installing a +10 arm, im smoking the tire...not inital hit of the clutch off the line. I notice i go half way with the clutch first then the rest of the way out. when i let the clutch out the second half thats when its lighting the tire up. The rear shock is tightened all the way and the tire comes very close to hitting the lisence plate on the back of the tiger undertail. The past 3 yrs I have run 17 psi no problems, I raised it up to 25psi and down as low as 10 psi and same results. only other change over the winter is i went +1 more in the rear. This has happend at 2 different tracks now so i dont think its track prep but always that possiblity. Dont know what to do at this point could use some feeback thanks.
almost_les
posted June 10, 2011 08:46 PM
tighten the rebound dampening
c-low
posted June 11, 2011 01:01 AM
try the hook up shinko its softer
posted June 11, 2011 04:20 AM
Pazx, the longer your swingarm is, the less weight you have on your rear tire. Less weight on the tire the more traction problems you are going to have. Tighten your rebound up, it sounds like when the shock is rebounding it's pulling the weight off the rear tire.
If you don't have a revalved shock now might be the time.
And get a tire that will hook. Either the Michelin power one or the hook up.
I run the power race soft 180/55 and I have zero problems with traction at 15 psi
dakota9498
posted June 11, 2011 05:46 AM
Looks like suspension is your culprit, sounds like the suspension is unloading after the initial hit and it is spinning. Needs more rebound dampening. With that big of a stretch a revalved shock would help, but a spring would probably be needed too.
2008 ZX14
pazx14rider
posted June 11, 2011 06:47 AM
I figured i wasnt getting the weight transfer i was at a 6in stretch. Ive seen some post of guys running busa springs is that because they are a stronger spring? I was looking at the Hook up but dont know anyone around who has really run one...one guy started running it last week so its uncharted territory for him.
posted June 11, 2011 07:22 AM
What do you weigh ?
posted June 11, 2011 08:27 AM
The spring isn't the determine factor as much as the valving in the shock. By what I have learned from the suspension guys, the shock "holds the bike up". The valving is what controls how fast it squats and comes back up. At 8", a spring didn't do much for me, I went with re valving and it works better for me.
pazx14rider
posted June 11, 2011 09:11 AM
What do you weigh ?
185 suited
pazx14rider
posted June 11, 2011 09:12 AM
Eklipse, anywhere you can send the factory shock to get revalved? any idea on price?
posted June 11, 2011 09:19 AM
Bmc is who done mine, I believe $175 or coby Adams sends them to litz. It's a little more than bmc.
pazx14rider
posted June 11, 2011 09:21 AM
what was your turn around time?
posted June 11, 2011 11:51 AM
Whatever shipping was plus he had it only one or two days. Very quick! Somewhere around 1 1/2 weeks for me considering I'm in ga and he is in cali
pazx14rider
posted June 11, 2011 12:05 PM
I went out and checked the rebound...it took 3 turns to hard maybe the problem?
Quarter Pounder
with Cheese
posted June 11, 2011 12:28 PM
set it too full hard and see what it does. You want it to return slowly, not boing back up after squating.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted June 11, 2011 12:36 PM
Both shock adjustors turned all the way in then back them out an 1/8 turn.. Your set up should work fine for your weight ..
Wheelie
Old Man
posted June 11, 2011 12:56 PM
if the rear tire is a stealth and not a 003 u-soft I don't think a revalved shock will make any difference with a harder tire.
wee
posted June 11, 2011 01:16 PM
wee
+1
RICH CRAFT 1
posted June 11, 2011 05:14 PM
+1
Red 06 ZX14 RR
pazx14rider
posted June 12, 2011 06:57 AM
I will give that a try. hopefully get a test and tune on saturday
pazx14rider
posted June 12, 2011 06:58 AM
Ordering a U-soft tomorrow hopefully between the shock adjustment and softer rear that will take care of it. Thanks everyone for the tips i will post up how i make out
posted June 12, 2011 04:16 PM
Do you ride it on the street? Why not order the hook up????
madnessracing
Vmax and Busa Beater
posted June 12, 2011 04:55 PM
how much pressure youre running on the tire?
Shorty's Performance
Team Madness Racing
pazx14rider
posted June 14, 2011 06:22 AM
I do ride the street, was told by the dealer (who races a busa with me) dont run a hook up if your running the street he just said the sidewalls are very soft might give problems.
0.37954998016357 seconds processing time
