BIKELAND > FORUMS > ZX-14.com > Thread: e85 map for 08 ECU with 06 injectors NEW TOPIC NEW POLL POST REPLY
Foster
posted April 19, 2011 06:39 PM
Anyone have an e85 map for 08 zx14 ECU with 06 injectors?
Or does anyone know the difference in flow % from the 06 to 08 injectors. So I can just modify my current 06 ecu e85 map.
Because it is really rich with this setup.
wrongway
posted April 19, 2011 06:53 PM
I am guessing 0 map with the setup you have ....
06 has 440 cc injectors,,, 08 has 330 cc injectors
440 / 330 = 1.3 ,,, that is 30 percent more ... i think that i went up 35% to go from gas to e85 , so you may just add a few percent if your map was on the lean side.
Roy
Foster
posted April 19, 2011 07:24 PM
Thanks for the info Roy. That makes sense.
I started with pump gas and the standard muzzy map for sidewinder with both sets of injectors and that is why I said it is rich with the 06 set.
I wasnt sure which way I wanted to go, so I did not put the e85 in this one yet, but it looks like It should work out fine.
01smokes
posted April 19, 2011 07:29 PM
How much are you guys picking up with the E85 on motor and are you guys adding any timing to your bikes or stock timing and just adding fuel foe the E85
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Foster
posted April 19, 2011 07:45 PM
on the dragbike I picked up a tenth as soon as I changed the fuel and added 30%. Then about another tenth when I tuned it a bit more. I played around with advancing timing a few degrees, but I really cant say it did a whole lot.
I havent run it on the streetbike yet, but I am sure it will run cooler and have better torque.
01smokes
posted April 19, 2011 08:04 PM
I've used E85 on my turbo bike I think I was one of the 1st to do it, but I was just messing with fuel with the zx14 but now with the genII I can get into the timing and maybe build a very aggressive tune with lots of timing or as much as it likes, I also plan on spraying the bike with E85 as well, just need a new fuel pump and I'll start messing with everything.
Foster
posted April 19, 2011 08:33 PM
Should work well.
01smokes
posted April 19, 2011 09:17 PM
Should work well.
Ya I hope so just wondering if it's gonna be worth it but .2 is worth it for me let's see if I can get the same results you I'll post up what I get. Oh how much MPH did you pick up if any??
wrongway
posted April 19, 2011 09:39 PM
rich posted up some results . He picked up 3 mph going to 46 mm throttle bodies and 3 more mph going to e85 on a stock motor bike.
Roy
Rich
Just havin' fun!!
posted April 20, 2011 01:00 AM        Edited By: Rich on 20 Apr 2011 09:00
That was right. I used E85 on a Friday and picked up a consistent 3 mph. We put 46s in Saturday and Sunday showed another 3 mph consistently. That was with stock motor and stock gearing.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
01smokes
posted April 20, 2011 05:29 AM
And that was just pour in and add fuel no timing??
01smokes
posted April 20, 2011 05:50 AM
Oh another thing are you guys running hotter plugs??
wrongway
posted April 20, 2011 06:18 AM
I run the stock heat range, even with a 30 shot . no timing changes on my bike or rich's bike . I did test +5 degrees on less dyno with no change in hp
Roy
posted April 20, 2011 06:31 AM        Edited By: Shane661 on 20 Apr 2011 14:31
Rich, what is your bike setup and suited weight? What were the dates and at which track?
What was your mph before and after?
01smokes
posted April 20, 2011 06:55 AM
Oh and rich I have a extra 06 ecu if you need one I can trade out for the 08 with you
Rich
Just havin' fun!!
posted April 20, 2011 03:15 PM        Edited By: Rich on 20 Apr 2011 23:17
Bike was SWB at the time. I was averaging 144 ish most runs, poured in E85 and added 35% through all fields and let the auto tune make changes. 3 147s in a row at Rockingham Friday evening, March 18th. Temp was in the 70s. I normally go to Fayetteville. Put in 46s on Saturday and ran mostly 150s at Fayetteville on Sunday. Temps were in the 60s.
I weigh 140 in shorts, add leathers and boots and all. Not sure of the weight. Bike has not been on a diet, except for street meg.
No timing change, no change in plugs.
0.22448897361755 seconds processing time
