BIKELAND > FORUMS > ZX-14.com > Thread: motor build advice. what makes more since. NEW TOPIC NEW POLL POST REPLY
serius blk
posted March 21, 2011 10:23 AM
ok in the process of building a 14 motor. Im at the point when i dont know which makes more since. I have two options. one use the stage 2 head that jim did for me and spend some money on the cams but keep it stock bore. option 2 is to use the 2mil pistons i have already and just get the motor bored but use the stock cams. I have stock bore 13.5 cp pistons and 2 mill 13.5 cp pistons. I want to run no2 on this motor and drive it on the street. Dont know if getting the cams even make since with the amount of money spent on them.
posted March 21, 2011 10:27 AM        Edited By: Shane661 on 21 Mar 2011 18:40
Since you plan to spray it, I would stick with the stock cams and go with the 2mm bore. The displacement will give you a good boost on the bottom/midrange (and on the top to an extent), and you can make the serious top end power with the spray.
0.2163450717926 seconds processing time
