BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 LM-2 hook up? NEW TOPIC NEW POLL POST REPLY
CajunBoyz
posted March 09, 2011 12:26 PM
ZX-14 LM-2 hook up?
I'm will have a LM-2 datalogger soon. To save me some headaches, What wires & where do i tap into for RPM, & TPS on a 06/07 ZX-14. Thanks
06redzx14
posted March 09, 2011 12:32 PM
Grab the y/white tracer at ecu this is tps 0-5 signal voltage. If your standing behind the bike it will be on the left side of the ecu 9th pin on bottom row on big connecter. WHITE/RED tracer top row 1st pin on little connecter from right is #1 coil grag rpm signal,both of these are on the ecu thats under the tool box come back aleast 3inches from connecter as not to pull against the poles when you reconnect
CajunBoyz
posted March 09, 2011 12:50 PM
Thanks ALOT 06redzx14, Just another question , I read where some have said the #1 coil wire is a "dirty rpm " signal ??/ & the logger reads it spiking all over the place??? Some have mentioned they r using rpm off the injectors?? Again thanks keep em coming..
0.36202692985535 seconds processing time
