BIKELAND > FORUMS > ZX-14.com > Thread: Gear/RPM/Speed Calculator NEW TOPIC NEW POLL POST REPLY
indynic
Lil Show, Lil Go
posted February 19, 2011 05:39 PM
I just asked this question, then did research. How to you calculate your speed, RPM when changing sprockets.
Here is great link:
http://www.bikerenews.com/Stories_Archives/GearRpmSpeedCalculator.htm
You will need this info for a ZX14:
Primary reduction ratio:1.541 (94/61)
Gear ratios:
1st:2.625 (42/16)
2nd:1.947 (37/19)
3rd:1.545 (34/22)
4th:1.333 (32/24)
5th:1.154 (30/26)
6th:1.036 (29/28)
Final reduction ratio:2.412 (41/17)
Now, all you have to do is change sprocket sizes and you get the info you need for street or strip.
NinjaNick
'08 ZX14 (Blue)
posted February 19, 2011 06:43 PM
http://www.gearingcommander.com/ has always been a great site.
zixxer14
Damn that was Quick
posted February 22, 2011 09:48 PM
Yep, with gearingcommander you don't need the ratios as it already has them. Makes it easier to find the gearing you need for any bike.
Audioboyz
posted February 23, 2011 03:59 PM
Yep gearingcommander even has different tire circumfrence,
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
0.31219983100891 seconds processing time
