BIKELAND > FORUMS > ZX-14.com > Thread: removing secondary flies NEW TOPIC NEW POLL POST REPLY
wynne67
posted November 21, 2010 07:59 AM
Hi,
Can someone please tell me if removing the secondary flies will cure the dreaded flat spot under 5000rpm or whether I would have to add a power commander as well?
CraigChrist
BAWLS
posted November 21, 2010 08:10 AM
what year model 14 do you have? If it's an 06/07 then removing the flies is absolutely necessary. That being said. Removing the secondary flies causes the need for a power commander. Otherwise you run the risk of hurting your motor due to the massive lean spike from 4-5k rpm.
60ft-------1.42
1/8th------5.97
mph-------119
zxbob
posted November 21, 2010 08:43 AM
http://www.bikeland.org/board/viewthread.php?TID=54388&FID=27
Bob
watthecu
PissingContestHere
posted November 21, 2010 11:36 AM
Geeeeeeeeeeeeeeeeeeeeeee HAaaaaaaaaaaa! I got something massive for ya. A fucking CLUE!
watthecu
PissingContestHere
posted November 21, 2010 08:02 PM
Hi,
Sir, is lightening as fast as air? To see lightening you see it in the air and does not that air flow that to ground get out day way weak old dead fish coming thru.
Sir, did you change the spark curve?
Sir, if you just stood next to the bike and whipped the throttle open, in theory, would the next cylinder keep firing out the ass faster than you can remove your hand it hit the rev limiter, yes or no?
Sir, if you remove fly, you have to literally yank out your wangiss hangiss outizz or do I look stupid to you?
wynne67
posted November 22, 2010 03:39 AM
Is there another product the same but cheaper than the power commander available?
00Busa
Trying to go FASTER !
posted November 22, 2010 08:56 AM
What year 14 do you have ? I have a used PCIII for an '06~'07 ZX14
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
INTIMIDA2OR
RED rider!
posted November 22, 2010 02:47 PM
These do the job and are cheap:
http://www.techlusion.com/TFI/TFItechnology.asp
'06 Passion Red ZX-14
*Lee*
posted November 22, 2010 03:55 PM
For a $10,000 motorcycle $200 for a pc is just a must.
watthecu
PissingContestHere
posted November 23, 2010 05:22 AM
Why is the qualifier question always thrown out with the baby and the water?
My bike has seen the subless, a 4 in 1 for the street meaning ~ Has a queit, don't say anything, muffler.
You look at maps and does not the bike run rich [on the way up] is slow you down?
Is this not a N/Azz purr rated like a pussy bike?
Is not the exhaust closed when the intake knows a vacuum pull and that tells guess who to calc the blend.
When did the exhale... Relax, take a deep breath, get in line like Ivan about to limp your bike. Brock about to be asked the qualifier question. Weirdwaysingworld is to get a clue on a sub-system not some ignition that has to follow hello is chickent jump.
Now there is a harley article I am beating brow with on another site is why the bike rolls out the van to take year trophy like the oldays.......... Not a fucking thing azz changed as if I took the same attitude then ass today. Cum get some trophy I need a cutter with muffler and the qualifier keeps shutting down the same answer once thatrick valve closes.
0.26321506500244 seconds processing time
