BIKELAND > FORUMS > ZX-14.com > Thread: Parts needed for 200mph NEW TOPIC NEW POLL POST REPLY
jlewis02
posted November 22, 2010 06:12 PM
What all do I need to run 200mph?
Parts I have
Muzzy m14 system
PCIII dyno tuned on 88pump
BMC air filter
Speedo Healer
Brocks Lowering links 3hole
Brocks Strap mounts
16,17t front sprocket
40,41,43t rear sprocket
Any info would be helpfull.
08 ZX14
1.57 60'
6.09@124
9.24@155
SWB 5400ft DA 50hp shot
posted November 22, 2010 06:20 PM
How much do you weigh, and how long of a distance are you willing to run?
jlewis02
posted November 22, 2010 06:27 PM
Im 155lbs in full gear
Im also at 3600ft above sea level
I would love to do it at maxton mile but I have 4-5 miles of open highway to do it also but would rather not.
08 ZX14
1.57 60'
6.09@124
9.24@155
posted November 22, 2010 06:29 PM
You will want to go with the 17/40 gearing. No air filter, and oxygenated race fuel. You should tune it with a data logger. You could come close in the mile this way.
If you want to do it in the mile for sure, a small 20 hp shot of nitrous on pump fuel should do it. Practice is the key.
jlewis02
posted November 22, 2010 06:33 PM
Thanx
I will have to get a spraybar for the spray then that way I can up it at the dragstrip.
What speed is 17/40 good for?
08 ZX14
1.57 60'
6.09@124
9.24@155
posted November 22, 2010 06:36 PM
Well, I have run 209 on 17/40, with a very big tailwind. But in still conditions I think it will max out at maybe 203...based on what has been seen at Maxton.
jlewis02
posted November 22, 2010 06:38 PM
Nice thanx
08 ZX14
1.57 60'
6.09@124
9.24@155
oldkawboy
posted November 22, 2010 09:09 PM
I went 197.8 a few weeks ago at Maxton tagging the limiter at the traps with 17/41.
Like Shane said, 17/40 should get you a tad over 200 if the bike will pull it.
Good luck,
Dan
BobC
posted November 23, 2010 01:16 AM        Edited By: BobC on 23 Nov 2010 09:17
Shane is spot on with his gearing, I found 17/40 was the most likely combination to crack 200, it needs to be the lowest which will still give 200, plus a bit, before the rev-limiter cuts in.
I made a 203.1mph pass in still conditions on this gearing and a 205.4mph pass on 18/41 but it was really over-geared and only made that speed because of a stong tail wind.
The lowering and strapping gives you an advantage because you can launch much harder but remember to perfect your aerodynamic tuck. Head down, butt on rear of seat, elbows in, toes on footpegs etc - all very important.
Hope you do it.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.20674800872803 seconds processing time
