BIKELAND > FORUMS > ZX-14.com > Thread: 48 throttle bodies zx14 NEW TOPIC NEW POLL POST REPLY
northernkaw
posted November 22, 2010 07:06 PM
well guys we are now out to 48mm on the size of the zx14 throttle bodies. got a set going on a 1570 motor. this motor made 245hp with the 44s. this should be good. I will let you know.
posted November 22, 2010 07:16 PM
oldkawboy
posted November 22, 2010 09:00 PM
I've just bought a set for you to bore to 47, should be getting them by Friday.
I was thinking the 48's would be getting pretty thin-walled but I'm sure you feel good or wouldn't be doing them.
What about the OEM stacks or aftermarket aluminum's working with the 47's? Will they fit okay or is a little work required?
Thanks,
Dan
watthecu
PissingContestHere
posted November 23, 2010 06:02 AM
"Cramming all that fuel and air into this amazing new engine is a ram air-assisted fuel injection system featuring larger throttle bodies (47 vs. 43mm) and sub-throttle valves."
WOT does dis do? Well, roundie, it narrows the engine so you need to get on a rice diet without government intervention you want to ride our bikes.
WOTap'INNs when you squeeze sardines in a can? Do fish look oval 0 O <<< How many fish can you stick in the can up day ass now thin wall...
Geeeeeeeeeeeeee HAaaaaaaaaaaaaaaaaa!
0.20473408699036 seconds processing time
