BIKELAND > FORUMS > ZX-14.com > Thread: Cams zx 14 -08 NEW TOPIC NEW POLL POST REPLY
FAST Z14
posted November 02, 2010 03:47 AM
Cams zx 14 -08
Hi guys ,need some info,we want to do the head on the 08 - 14,should we keep the cams stock or should we cut the cams aswell,there seem to be some sort of disagreement here in South Africa among some tuners.
What do the Americans recommend stock or modified cams ?
The bike only get used for normal street riding and the odd street racing, no drag racing .
FOLY HUCK
Y2KZX12R
CompetitionCNC.com
posted November 02, 2010 04:09 AM
The reground cams are a waste of time and money. They aren't big enough to make enough difference for the $$$.
To really make any difference you need to put standard bore higher compression pistons with deeper valve reliefs in it and then go with the weld-up Web Cams. The .395" on the intake side will wake it up as long as you have the added compression.
Y2KZX12R
CompetitionCNC.com
0.37323093414307 seconds processing time
