BIKELAND > FORUMS > ZX-14.com > Thread: no fuel priming, or no starter motor, NEW TOPIC NEW POLL POST REPLY
kiwi12
posted October 04, 2010 02:58 AM
Ok, i am lucky im bald, because i would have pulled out all my hir by now,,,,,,,,
I have just changed my main loom, ( as I was having voltage drop )
and in doing this I dropped the engine, and removed the old loom. and replaced with a second hand 2002 loom,
my bike is a 03.
i took off the fuel tank, and replaced once the engine was back in the frame.
i did disconnect the tps, , and everything eles that was attache .. but have replaced everything back to the new loom.
w
Now when i turn the ignition on, all i get is the clocks starting up, but no fuel priming, or no starter motor,,
i stll have the radiator off,
any helps
,, please ,,
what is going on in here?
Hellmutt
posted October 04, 2010 04:37 AM
What are you working on? ZX12 right? Is it fitted with a PC? Fuses all good?
No prime, no starter power sounds like ( 1 ) poor connection somewhere ( 2 ) battery is shot?
Check your volts vs. amps on your battery as well as connections to and from.
Ensure your grounds are all tight..........anyone else chime in with better ideas?
kiwi12
posted October 04, 2010 11:40 AM
yep its a Zx12
no PC
Ill go theu all the connection again and check bat
TH1RT3EN
Trial And Error Control
posted October 05, 2010 02:58 AM
just so i ask did you make sure your kill switch was set to the run posisition and not turned off? It will kill the fuel pump and the starter as well..
Just a thought
Patrick
Hellmutt
posted October 05, 2010 09:22 AM
Elementary, yet easy to overlook sometimes - good call on that one
Would be sweet if thats all it was especially after all that harness work
he'd just done
68gts2
hobbies ( Beating you !!! )
posted October 08, 2010 11:06 AM
Well what is the verdict? Is it alive?
INTIMIDA2OR
RED rider!
posted October 08, 2010 01:36 PM
'06 Passion Red ZX-14
*Lee*
0.2121639251709 seconds processing time
