BIKELAND > FORUMS > ZX-14.com > Thread: speedometer NEW TOPIC NEW POLL POST REPLY
ambull
posted August 30, 2010 06:07 AM
speedometer
What is the way to get the speedometer more accurate..I know u can get a speedohealer but is there any other way..Someone told me to grind one end of the sprocket nut..Thank's
ambull
posted August 30, 2010 06:44 AM
I meant grind one end off the speedo sensor
c-low
posted August 30, 2010 07:00 AM
i was told thesame thing where you put the front sprocket the sppedometer sensor griend one tooth off
CajunBoyz
posted August 30, 2010 07:12 AM
Grind down one corner of the square frt sprocket nut,
sj1400
posted August 30, 2010 08:30 AM        Edited By: sj1400 on 30 Aug 2010 16:31
My speedohealer caused the speedo to not work. Suspect a short in the plug. I believe theres a dual mode version or enhanced speedohealer - anyone using this version ?
Can I switch modes on te fly ?
For me this would be a huge benefit once the ecu is programmagle like the Busa guys - remove speedo healer + remove the fuel cut off at redline if thats possible.
BobC
posted August 30, 2010 12:03 PM
Don't grind a corner off the countershaft sprocket nut if you want to get the speedo more accurate.
This is only done to defeat the top speed limiter by fooling the ECU with an under-read of the speed pulses. You'll be getting a minus 25% speedo reading when you probably only need about minus 7% to make it accurate on stock gearing.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.22781896591187 seconds processing time
