BIKELAND > FORUMS > ZX-14.com > Thread: Help With Leaking Fuel Tank NEW TOPIC NEW POLL POST REPLY
WARBIRD
posted August 03, 2010 04:59 PM
I am posting this here as well as the zx12 and Dragbike forums...any help would be appreciated...........
Hey fella's..............I am working on a friends 03 ZX12 and it has a fuel leak from around the back plate where the sending unit is bolted. I replaced the gasket that goes between the back plate (up against the fuel tank ) and the top plate. I poured fuel in a little at a time with the tank propped up and it appears to be coming from between the back plate and fuel tank. Is this plate welded to the tank? There is no rust in the tank that I can see...........and the gasket is lined up properly. ( it will only line up all four holes ONE way. )
Any help or insight would be appreciated.........
Thanks,
Charles
I'd Rather Be Roadracing.
extremelean
posted August 03, 2010 06:26 PM
cracked tank...replace if possible...chk for paint around gasket surface
WARBIRD
posted August 03, 2010 08:12 PM
Thank you............very much.....
0.283038854599 seconds processing time
