BIKELAND > FORUMS > ZX-14.com > Thread: hurt motor???? NEW TOPIC NEW POLL POST REPLY
01smokes
posted August 03, 2010 12:39 PM
hurt motor????
Well I pulled the pan on the 14 and everything looks good under there no gold flakes at all, well anyways the knocking sound comes and goes, and the bike will start and run with no smoke at all but it won't idle by its self, ill have to keep it going. Also when I bring up the RPM it feels like its working and putting a load on the motor, and boost will build and hold if I just rev it up and hold it at about 5k RPM, what could this be guys?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Big_T112
posted August 03, 2010 12:52 PM
Deformed pistons maybe from heat. Sounds like some tight wrist pins if it feels like it's in a bind. be careful reving it because it could break one off. Hard to really say without hearing it my self but for sure you hurt a rotating assy. With as many miles as you have on it just pull it down, check everything and see what the problem was.
INTIMIDA2OR
RED rider!
posted August 03, 2010 01:53 PM
There's probably a melted piston or 2 causing the tight motor. Could be the pins or bent rods too.
If it were bearings you would be hearing plenty of noise and you would have seen fools gold in the oil pan.
Check the spark plugs , you might or might not see a little aluminum from the pistons on them.
Try turning the motor over by hand and listen for where any noise comes from.
No matter what you do though it looks like the motor is gonna have to come apart.
'06 Passion Red ZX-14
*Lee*
extremelean
posted August 03, 2010 06:36 PM
Check cams for siezure, check valve springs for breakage, check for broken valve shims.
Not having the machine in front of me is only a guess.
If you have a turbo make sure the turbo bearing isnt siezing up, lack of oil to turbo will cause almost what you're speaking of...should be a screen for filtration to turbo bearing.
Compton
posted August 03, 2010 06:39 PM
did you check to see if the stator rotor is still bolted to the crank? i've seen em come loose and sound like a bad knock.
b.w.
INTIMIDA2OR
RED rider!
posted August 03, 2010 07:40 PM
*Lee*
01smokes
posted August 03, 2010 08:48 PM
I'm out of town for a few weeks when I get back home ill get some pics posted up with out the pan on. And ill also start dropping the motor than too, regardless what it is I want to build this thing already and make some real power 330hp just isn't gonna cut it anymore
INTIMIDA2OR
RED rider!
posted August 03, 2010 09:47 PM
330 hp isn't cutting it anymore
Right on man!
*Lee*
blackbullet76
posted August 04, 2010 05:09 AM
Yeah, 330 hp's is just plain whimpy on a bike :-O
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
68gts2
hobbies ( Beating you !!! )
posted August 04, 2010 06:46 AM
Smokes have you done a compression and leakdown test to see if all the holes are equal?
posted August 04, 2010 08:38 AM
Yea.. Who would be happy with 330hp.
0.4125988483429 seconds processing time
