BIKELAND > FORUMS > ZX-14.com > Thread: Electrical short NEW TOPIC NEW POLL POST REPLY
Sgt Reyes
ZX14 POWER
posted August 01, 2010 09:44 PM
Electrical short
Can smeone plase tel me what can b wrong with my ZX14 .. Every now and then my digital panel shuts off and it wont start,, ill have to rock it a ittle for it to start,, a few times I have been on the highway doin 80Mph and it jerks like is going to loose poer or not getting enough fuel.. and my panel shuts off an my gages cycle up and down the same way they do when you start the bike,, butthen it goes away and it rides normal. Please someone give me some hints to solv my problem! thx Sgt Reyes
SgtReyes
LAB3
posted August 02, 2010 02:33 AM
Welcome, there is a tilt sensor in the nose of the front of the fairing. Check it and some models have a Immobilizer system, check the ground.Also look at the battery cables and make sure they are clean and tight.
Sgt Reyes
ZX14 POWER
posted August 02, 2010 04:06 AM
Thanks LAB3, I will try that, I had aeeing also about my batteries cabls,, thxs a bunch!
SgtReyes
scottfarm
posted August 02, 2010 04:28 AM
I would pull wiring harness conector for the display unit, spray wd-40 in connections and reconnect. Your tilt sensor shuts off the fuel pump.
LAB3
posted August 02, 2010 06:42 AM
You are correct that the Vehicle Down Sensor (tilt sensor) shuts off fuel pump, but
the ECU also shuts down the fuel injectors, and the ............ Ignition System. I should have
posted to check the battery cables. First.
zx6reaker
D&D's, Frame sliders, pcIII
posted August 02, 2010 08:25 AM
Had the same prob with my 07. it was the battery cable - side.
Loud pipes and bright lights save lives.
0.23165798187256 seconds processing time
