BIKELAND > FORUMS > ZX-14.com > Thread: oil in throttle body NEW TOPIC NEW POLL POST REPLY
soulshaker
yoshimura pipe pc.v flies out
posted July 23, 2010 04:18 AM
i removed my gas tank, and the two metal plates that sit on the frame, in the housing above throttle body there there was a pool of oil. can someone tell what would cause this
soulshaker
zxbob
posted July 23, 2010 05:06 AM
Its pretty comon in the 14 . . . . just check your oil level and make sure its not over filled.
A little more detail on the bike as far as year - how many miles - engine mods would
help.
Bob
soulshaker
posted July 23, 2010 05:51 AM
thanks bob,its a 09 4500 miles, maping not done yet,no engine mods
soulshaker
jarhead
posted July 23, 2010 12:37 PM
Very common on the 14, there are ways to stop it but it really does not hurt. Like Bob said just make sure the bike has oil and you are good. I clean it up everytime I am in there but it never really amounts to much. My bike has over 10k miles and hundreds of nitrous passes and it still goes like hell.
soulshaker
posted July 23, 2010 07:43 PM
thanks for the info, got the bike dynoed maped and oli and filter changed my mechanic told me the same thing,its good to have so much info at the tip of your fingers
soulshaker
man00
posted July 24, 2010 08:44 PM
seen other posts saying that Amsoil was the cause, at least in some cases
LAB3
posted July 24, 2010 10:26 PM        Edited By: LAB3 on 25 Jul 2010 06:31
Bogus...... oil is oil........over fill a 14 just a little and WOT a few times a little oil blows by. The
engine case has to release pressure . Kind of like a sub woofer box is ported. Pistons on
down stroke make pressure in crankcase...... vent tube goes into air box. Ream the piss
out of a engine and some drops of oil vents with the air pressure. Low RPM=less air being
released from crankcase. Keep the oil level in the center of the lines on sight glass
and have fun. And yes I use Amsoil and no I don't sell it. :-)
Louis
Dark14
posted July 25, 2010 07:37 PM
My 07 had what seemed to be an unusual amount of oil in the airbox when i removed the secondary throttle plates at around 5,000 miles, but it always ran like a champ and i never had to add oil to it between changes.
My 08 didn't have a single drop of oil in the airbox when i removed the secondary throttle plates at only 800 miles.
like bob said it's common.
johnbull
posted July 26, 2010 07:28 AM
If u ever have the sump off......pull out the black rubber breather pipe going down into the sump bowl!
John Bul Racing. Malta.
LAB3
posted July 26, 2010 07:54 PM
Explain in more detail..??
Louis
BobC
posted July 27, 2010 04:29 AM
Louis
When the crankcase pressurises - if the bottom of the vent pipe is immersed in the sump oil, then oil will be forced up the pipe into the airbox. If the pipe is above the level of the oil then venting can be achieved without forcing oil up the tube.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
LAB3
posted July 27, 2010 05:17 AM
Louis
OK.... I see what you are saying. I have not had the pan off my 14 and did Not realize
Kawasaki had the vent so far down in the crankcase. Thanks to you Both... :-)
Louis
0.22797584533691 seconds processing time
