soulshaker
yoshimura pipe pc.v flies out
posted July 26, 2010 12:59 PM
how to remove tail light lens
does any one no-how to remove or seperate the tail lite lens from the tail lite housing? i want to put some strobes in them.
soulshaker
Quarter Pounder
with Cheese
posted July 26, 2010 02:36 PM
it's sealed....
If you want, buy a spare to experiment with. Put in oven at 250 for about 10 minutes to soften the adhesive...you can then separate the halves. Do at your own risk though...and monitor the light while its in the oven.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Wheelie
Old Man
posted July 26, 2010 02:38 PM
Edited By: Wheelie on 26 Jul 2010 22:38
dremal tool
wee
epd345
posted July 26, 2010 05:14 PM
I dont know how well its sealed, everytime I wash my bike I see some soap suds in it.
dakota9498
posted July 26, 2010 07:05 PM
When I bobbed the taillight on the ZRX I just soaked it in some hot water for a few minutes and the adhesive was soft enough to pull it apart.
2008 ZX14
zixxer14
Damn that was Quick
posted July 26, 2010 07:26 PM
Plastic explosives, of course!
posted July 26, 2010 11:14 PM
You could drill a hole from the backside and put a rubber grommett in it so you can still run your wire through. Or silicone.
soulshaker
posted July 27, 2010 03:34 AM
the wire board is at the back, dont want to drill thru that, may-be il drill thru the side
soulshaker
Hellmutt
posted July 27, 2010 04:56 AM
seen a lot of stunt guys that have drilled out their headlamp housing to accomodate strobes........I'm sure you could do this with your brake lamp, I'd just aim for the bottom or lower sides to keep water from running inside easier......plus if it's at the bottom or low in the housing you can yank the grommet to let water out
