BIKELAND > FORUMS > ZX-14.com > Thread: Error code 24 NEW TOPIC NEW POLL POST REPLY
sj1400
posted June 24, 2010 01:34 PM
Error code 24
Stumped with fuel injector error and no speedo.. Despite swapping out the speed sensor and bypassing the speedo healer. Wiring verified up to harness. Battery was weak so it was charged then disconnected overnight.. Not sure what else to do.. Manual states ECU replacement.. Anyone run into this issue
LAB3
posted June 24, 2010 02:19 PM
What year 14?
sj1400
posted June 24, 2010 05:57 PM
2006
posted June 24, 2010 07:59 PM
error 24 is the speedo. can't understand whay the ecu must be changed.
sj1400
posted June 24, 2010 08:01 PM
Issue 1 - no speedo despite swapping speed sensor.
Issue 2 - fuel injection error message last week.
Factory manual stated if wiring and sensor verfied then ecu must be replaced.
posted June 24, 2010 08:16 PM
shitty
dcjens
Wet side of Washington
posted June 24, 2010 08:18 PM
I have a spare ecu..06
Black 06
sj1400
posted June 25, 2010 11:02 AM
All set guys - SEARCH feature is awesome..
Went through some old posts and determined there had to be a break in the circuit.. Rechecked the wiring.
Removed the speedohealer and presto - speedo works.. Once the bike reached 20 mph the fuel injection error cleared.
LAB3
posted June 25, 2010 11:57 AM
Glad it worked out............Odd... you posted you by-passed the speedo healer.Maybe this is like the ground on the PCIII in wrong location.
INTIMIDA2OR
RED rider!
posted June 25, 2010 08:19 PM
Interesting! I've never hear of that problem happening.
'06 Passion Red ZX-14
*Lee*
Compton
posted June 26, 2010 07:35 AM
this is why my speedohealer sits in the parts bin, never to be used again. lol
b.w.
LAB3
posted June 26, 2010 09:48 AM
My heal tech speedo healer works great. had it two years and have reset sevral times for different gearing and now a 55 series rear tire.
LOCK 2121
posted June 26, 2010 09:18 PM
If you don't mind , how much diffrence does a 55 series make ??
gilberjj
Friend of Fast
posted June 26, 2010 09:23 PM
I loved the 55 on my bike when I was riding it on the street. It really improved turn in, and make the bike feel more sporty. It's essentially like taking away a rear tooth on the sprocket (going -1) as far as gearing goes. I would go -1 up front if you put on a 55 rear.
LAB3
posted June 27, 2010 04:58 AM
Great for turns but not the best profile for drag racing. The taller rear 55 is like -1 tooth on rear or so.
My 14 turns quicker with a 55 series rear. I use a Michelin Pilot Power 2CT 190/55/17
Gilbertjj is right on the 16 tooth front, really helps if you are a 200 pound rider. If you do go with a 16 front.
get the Kawasaki Zephyr 16, it fits the 14 and has the material on each side so all is quiet
-1 on front is like +2 teeth on rear. 16/43 is max for a stock chain that is fully stretched in.
Step0214
Step0214
posted September 06, 2013 06:51 PM
Question for 2006 Kawasaki ZX14... Replace the fuel pump twice and now replaced the ECU, bike cranks but has a FI error 24..... PLEASE HELP,, Have read earlier post but a little confused....
Stephanie
Stephanie I. Luster
0.31148505210876 seconds processing time
