BIKELAND > FORUMS > ZX-14.com > Thread: Is it possible to run in the 8s at 240pd no nitrous NEW TOPIC NEW POLL POST REPLY
serius blk
posted June 04, 2010 03:58 PM
Now i am going to lose weight but i want to know if my expectations are to high at the current weight. My 14 is 8 over with brock alien 16/47 gearing and shock revalved. My motor has a ported/polished head that is milled a bit. With heavy duty valve springs and degreeed cams at 104/106. Thin head gasket, velocity stacks, bmc race filter. I also have heavy duty springs with the spacers in the clutch. Dont know what kind of power its making but i did run 6.21 after a yr of not riding it. Thats with a 1.5 60ft. Im still getting things dialed in on it. I know i have to do alot better than 1.5 and my mph was only 114. What i dont understand is i was doing the same times with the same 60ft last yr with the stock motor and 16/44 gearing. Mph was the same. Im trying to see what gearing will work the best. It only took me 3 tries to run that 6.2. So im sure after some more seat time it should be better. I want to run in the 8s without nitrous. Thats the goal. Is it possible. At this weight.
serius blk
posted June 04, 2010 03:59 PM
head is Jims cnc stage 1
posted June 04, 2010 04:04 PM
What is the combined weight, bike and suited rider?
serius blk
posted June 04, 2010 04:06 PM
dont know. never been weighted.
serius blk
posted June 04, 2010 04:08 PM
i do have that 1pd light battery and some lighter zx636 wheels soon. I know that will help a bit. But for now lets say the stock weight plus me.
kawasakijockey
posted June 04, 2010 04:14 PM
Man, you got a tough row to hoe. Your 1/8th miles will have to be low,low 5.80's to make a 8 second pass on motor. This time of the year is a no-go anyway. Get your practice in and good luck come fall.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Quarter Pounder
with Cheese
posted June 04, 2010 04:17 PM
Not at that weight IMO.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
LeonidasZX14
posted June 04, 2010 04:27 PM
I do not think so either.
09' ZX14
posted June 04, 2010 04:35 PM
you may need a longer swingarm
LeonidasZX14
posted June 04, 2010 04:38 PM
I think even with a stroked motor it would be close. Weight is key.
09' ZX14
osr
posted June 04, 2010 06:25 PM
i went 5.90 @ 119 2nd pass ever and weighed in a 245 naked that night-- so if it takes a low 5.80 i think it is possible -- im stock bore and stroke with OSR headwork! hope to get it tuned and run next weekend -- it will be a while before I get 1/4 mile though
posted June 04, 2010 06:33 PM
I weight 190 this morning and went 1.37 60ft 5.77 1/8 and 9.04 1/4 @149
DA was 2,064ft
I can't get a 8, if you do good luck
Big_T112
posted June 04, 2010 06:54 PM
Put a dry shot on it. that will do it.
FlatoutBu
posted June 05, 2010 06:04 AM
I have been as fast as 9.00 at 240 naked....and 9.00 at 195 pounds suited...so i'm still scratching my head over that one.
06 Blue 14
9.008 at 153mph @ 195 suited
kawasakijockey
posted June 05, 2010 06:40 AM        Edited By: kawasakijockey on 5 Jun 2010 14:41
Hey....When you ran that 9.00 naked, did they call the cops?? just curious...
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted June 05, 2010 06:41 AM        Edited By: kawasakijockey on 5 Jun 2010 14:43
It will be tough but I would never say the man couldnt do it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Quarter Pounder
with Cheese
posted June 05, 2010 08:04 AM
Better air....just a guess
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
oilfieldtrash
Kawasaki enthusiast
posted June 05, 2010 08:22 AM
The BMW comes with a mid 8's guarantee up to a 350lb rider.
'07 white S.E. ZX-14 sold
Quarter Pounder
with Cheese
posted June 05, 2010 09:28 AM        Edited By: Quarter Pounder on 5 Jun 2010 17:29
sure, show that one please.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
serius blk
posted June 13, 2010 09:45 AM
Ok guys. My second time at the track. I put the zx10 wheels on it and mr12 with the air filter out. I finally learned how to take off on it. I have been doing 1.5 60ft but went down to 1.46 was my best. Ran a 5.97 at 118. I couldnt dump the clutch because it would grip then spin. Once i started dragging it a bit it worked better. The wheels and that mr12 kick ass. I also went down to a 46 in the rear. Now if i can master the launch and loose 25 pounds. I know ill can get in the low 5.80s. This motor is making power for sure.
posted June 13, 2010 03:27 PM
You will get it, just takes time with that left hand!!
FlatoutBu
posted June 14, 2010 05:09 AM
Nope, but that catalyst seat was hell on my scrotum.
06 Blue 14
posted June 14, 2010 02:16 PM
it's not the seat itself, it's the clips in the front that would catch a nut hangin too low!
CraigChrist
BAWLS
posted June 14, 2010 06:28 PM
My problem is that since I have to tuck my nuts behind me to keep from getting caught on the clips I tend to slide back and smash them... it sucks pretty bad lol.
60ft-------1.42
1/8th------5.97
mph-------119
FlatoutBu
posted June 15, 2010 09:09 AM
You ever have the seat come off? I have, the clinch factor was pretty high at that moment. The bolts pulled right thru the fiberglass, washer and all. Ever since, i put alumiumn tabs above the screws and tapped the screws out for 1/4-20 bolts.
06 Blue 14
0.24319696426392 seconds processing time
