BIKELAND > FORUMS > ZX-14.com > Thread: Anyone haul the 14 in a pickup NEW TOPIC NEW POLL POST REPLY
Bluebyyou
Gettin My Curve On
posted May 09, 2010 10:40 AM
I need to haul my bike to another state. I have a small GMC Sonoma and length wise it will fit with the tailgate down. I have a Canyon Dancer and plenty of tiedowns. Problem: I have no wheel chock and can only secure it to the factory tiedown loops in the corners of the bed. Should I attempt to haul it this way or is it too risky?
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
gilberjj
Friend of Fast
posted May 09, 2010 10:45 AM
Take off the front fender, then you can plant the front wheel into the corner of the box. Or you can just put it in the middle, but I would be afraid of it buckling. Harbor freight has wheel chocks for cheap.
madnessracing
Vmax and Busa Beater
posted May 09, 2010 11:48 AM
I always haul my bike on a tacoma short bed and the rear tire always seat right on the edge of the tailgate! at first i used to get scared all the time but then i got used to it! I only use 3 strap 2 in the front each side and one in the across the rear wheel!
Shorty's Performance
Team Madness Racing
zx14fan
posted May 09, 2010 11:56 AM
I have a tacoma that I hall my 14 in all the time.For the front cut two 2x4s from one side of the bed to the other then two 4x4s between the wheels up and down then screw them to the 4x4s from the back side and that will allow a place for the front wheel and will hold it in place firmly.
juanvaldex
Coffee junky.
posted May 09, 2010 11:58 AM
I hauled my ZX11 many times on the back of my S-10 pickup. same as you. never had any problems. i did put a piece of board in front of the wheel so as not to buckle the bed toward the cab of truck. just put it in gear and tied it down. tail gate down.
Midnight saphire Blue. ZX14
posted May 09, 2010 01:01 PM
If you do the canyon dancer tight enough, it won go anywhere.
Bluebyyou
Gettin My Curve On
posted May 09, 2010 01:09 PM
Ok guys, some good ideas. Txs I feel better about the whole idea now.
Superman T
posted May 09, 2010 02:12 PM
SWB?
3000psi and falling
posted May 09, 2010 02:32 PM
Ive hauled mine in a similar truck (GMC Canyon) With a home made front wheel chock, and soft bar strap with regular starps on rear , and the tail gate in the 45 degree postion. Ive drove all over the countrty like this, even over the rockies on a 2 lane twisty highway with no problems.
Sergent
posted May 09, 2010 02:47 PM
just put it in there and put something in front of wheel so fender doesnt hit and tie it down done it for years never had a problem
68gts2
hobbies ( Beating you !!! )
posted May 10, 2010 05:40 AM
+1 on the Harbor Freight wheel chock for 39 bucks,and it doubles a a good track stand.
Hellmutt
posted May 10, 2010 09:29 AM
My 14 is at stock WB and I have a shortbed Tacoma........haven't tried to squeeze her in yet, but my dirtride fits fine with the gate down -- rear tire hits just past the edge of the bed, if it had a flat tire I could probably get the gate shut -
posted May 10, 2010 12:08 PM
I got one of these 2 weeks ago. It's the shit for $40!
zxbob
posted May 10, 2010 04:07 PM
If you had a ZX-10 fender . . . . . you would'nt need to remove it !
Bob
68gts2
posted May 11, 2010 03:53 AM
If you had a ZX-10 fender . . . . . you would'nt need to remove it,but the front of your bike would look,well just wrong.
Bob
TampaGunSlinger
posted May 11, 2010 09:24 AM        Edited By: TampaGunSlinger on 11 May 2010 17:25
the zx14 fit in my 04 dodge dakota short bed/ single cab with the tail gate up with the stock front fender but it fits better now with the zx10 front fender..
gilberjj
Friend of Fast
posted May 11, 2010 09:58 AM
4 bolts and the 14 fender is off. Easy to do, and prevents scratches.
Bluebyyou
Gettin My Curve On
posted May 11, 2010 10:04 AM
Nevermind guys, thanks for your ideas and tips. I found a better option at Uhaul I rented a trailer for only $14.95 for the day.
0.24420213699341 seconds processing time
