BIKELAND > FORUMS > ZX-14.com > Thread: removing spark plugs NEW TOPIC NEW POLL POST REPLY
freddie900
zx 14 2007
posted May 06, 2010 03:28 PM
I cant download the PDF file so I can remove the spark plugs. could someone post how to remove them please.
rtbain
old, fat and slow
posted May 06, 2010 04:01 PM
Remove the plastic
Get a 14mm ratcheting box end wrench
Use the factory plug wrench
Carefully remove the stick coils
Put the factory plug wrench down the hole
Use the ratcheting 14mm box end wrench to remove spark plug
If the plug drops out of the wrench use a magnet to remove spark plug
Randy
  Ignore this member    Click here to visit rtbain's homepage.
zxbob
posted May 06, 2010 07:37 PM
"Use the factory plug wrench"
It will make your life easyer !
Bob
68gts2
hobbies ( Beating you !!! )
posted May 07, 2010 03:44 AM
Bobs right the factory wrench is a really good tool.
0.26172089576721 seconds processing time
