BIKELAND > FORUMS > ZX-14.com > Thread: replacing wheel bearings NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted May 06, 2010 03:24 PM
Is there a good way to test wheel bearings to see if they need to be replaced? And how hard are they to replace. I'm fairly sure they need to be pressed in/out. can it be done without a press reasonably or is this something I need to take to a shopp and have done?
Loud pipes and bright lights save lives.
rtbain
old, fat and slow
posted May 06, 2010 04:08 PM
Bad bearings will usually have excess play or rough spots. What makes you suspect the bearings are bad?
If they require replacement have a good machine shop do the work. It’s very easy to muck up a bearing pressing it in. This is especially true if you plan to install ceramic bearings. These are very delicate and expensive.
Randy
  Ignore this member    Click here to visit rtbain's homepage.
zx6reaker
posted May 06, 2010 05:25 PM
I hear a clicking (like once or twice) when I take off. also the tires, both front and rear, don't free spin that well. I can't get a full spin out of the rear and barely a full spin out of the front. I also hear a noise when I spend the tire. It's not quite a grinding, but something rubbing...almost like the brake pads on the rotor.
zx-14lvr
posted May 06, 2010 05:54 PM
then maybe it might just be the brake pads on the disk?? investigate that first..remove the pads and then free spin the wheels
rtbain
old, fat and slow
posted May 07, 2010 03:34 AM
Might be easier to remove the calipers. The wheel should spin freely.
Randy
0.23920702934265 seconds processing time
