BIKELAND > FORUMS > ZX-14.com > Thread: Dynojet quick shift, trouble!! NEW TOPIC NEW POLL POST REPLY
Dingus
IIIIIhhhhaaa!!! Ride the limit
posted April 22, 2010 03:03 AM
Anyone who has a dynojet quick shift on their ZX-14, and got it to work ??
I have just put on a PCIII usb with a 502 map, and now I am trying to connect a dynojet quick shift to it, but I cant get any contact with the quick shift program, it says " error device 0" and no contact with the PCIII. I have 3 wires from the shift, red, blue, and green, maybe anyone here knows in wich port on the PCIII they are supossed to go in to !!?
Andersen
Norway
Black ZX-14 07mod, yoshi slip-on, bmc filter, vortex rearset, short pazzo levers, puig DB, PCIIIusb, quick shift, 16-41 drive.
zxbob
posted April 22, 2010 03:47 AM
The plug on the quick shifter plugs directly into you PC-III.
Dumb question - with a laptop hooked up to the PC-III, did you "enable"
the shifter ?
Bob
Dingus
posted April 22, 2010 03:54 AM
Yeah, I did enable it, but then I got the message " no pcIII connected"
The problem is that I did buy a used quick shifter, and it did not have the white plug, just 3 wires with the sockets on.
zxbob
posted April 22, 2010 05:55 AM
I know where to plug them in if you can get the plug . . . . . . and I have the quick shift
CD you need to install it.
Bob
reypac24
Old Fart!
posted April 22, 2010 07:35 AM
the quickshifter was a simple plug/play. hardest part was adjusting but once its set it works great
Rey
Red 2006 ZX-14: Green 2000 ZRX-1100; Blue 1977 KZ-1000 LTD;
NINJA12
posted April 22, 2010 09:59 AM
You can use the plug from a PC battery adapter.
SixSixoh6
posted April 22, 2010 10:03 AM
you get that error when your battery is dead or almost dying. get a fresh 9v and it should work
zxbob
posted April 22, 2010 11:09 AM
Bob
Dingus
posted April 22, 2010 12:28 PM
Ok, thank you all, I will try this.
Keep riding safe : )
(still is cold here in Norway, snowing today )
Dingus
posted April 23, 2010 07:28 AM
Someone have a link to download the quick shift program ?? I dont have the cd.
0.22666382789612 seconds processing time
