BIKELAND > FORUMS > ZX-14.com > Thread: Dumb/quick PC III Question NEW TOPIC NEW POLL POST REPLY
Shogun
posted April 14, 2010 10:12 AM
Sorry in advance for the dumb question, but here goes...how can you be sure you're PC III is working? I've ridden my 14 very little the last few months and it is sluggish starting and a little rough running. May just be a weak battery and/or lack of running time but just curious about the PC III.
Thanks for any input.
06 ZX14 - Arata exhaust, PC III, McIntosh Ext swingarm, Vortex lowering links, Racetech rear shock, Marc wheels, To be continued...
gilberjj
Friend of Fast
posted April 14, 2010 10:15 AM
I've heard that every once in a while you should reload your map. Apparently sometimes the file can become corrupt....... who knows. but give it a shot
speedgene
posted April 14, 2010 03:02 PM
Remove the (+) wire of the PC for testing purposes only. Test ride the [stock base map] to tell if the drive-ability list you stated has cleared up some, most, all.
E-tard
68gts2
hobbies ( Beating you !!! )
posted April 14, 2010 03:32 PM
I believe Brock says its a good idea to re-map and re-set throttle position sensor at every oil change as part of your maintenance schedule. maps become corrupted,and throttle cables stretch and are adjusted which changes its value to your pc. My throttle position sensor was off 12 percent when i checked and re-mapped before 1st ride of the season.
zxbob
posted April 14, 2010 07:08 PM        Edited By: zxbob on 15 Apr 2010 03:10
What these guys say about checking a MAP is correct !
If your not sure its working - Start your bike, rev it up and watch to see
that the lights on the PCIII and moving up and down with engine RPM.
Bob
...................... and make sure you have a good ground !
youngninjadude
posted May 11, 2010 06:48 PM
How did you check it?
68gts2
posted May 12, 2010 01:09 PM
That's a good question since you don't have a pc yet Youngninjadude. I feel sure Smokin knows the answer to this one if you ask him. You could see big gains in your skoot (sorry Smokin its in my brain now) with a pc even with stock exhaust because of the factory over rich condition.
0.21865797042847 seconds processing time
