BIKELAND > FORUMS > ZX-14.com > Thread: wheres my mph NEW TOPIC NEW POLL POST REPLY
moses
posted April 13, 2010 09:17 AM
wheres my mph
i have an 09 zx14 yosh r-77 pipe no commander lowered 6 over stock gearing . 2 weeks ago first time at the drag strip. leaving at 7k still bogging a little bit then shifting at 11k. 1.67 60ft 6.68 1/8@110 10.1@136.59 im 235 suited. i know i need practice, but i thought the mph would be much higher. i was low on fuel so i put 1/2 gallon of 103 race fuel. i was told after the fact that would actually slow the bike down
posted April 13, 2010 09:23 AM
Don't worry about your MPH , it will come when you learn to ride the bike .. It is all seat time ..
dakota9498
First is the Yosh a slip on or full. Either way you need a power commander with a proper map. And I definitely wouldn't run the race fuel, that probably hurt a little as well. If you want to run something other than pump gas get a map made for some MR-9 or MR-11.
2008 ZX14
LeonidasZX14
posted April 13, 2010 09:44 AM
Are you using your clutch to shift? If so you should pick up a ton of MPH when you stop.
09' ZX14
gilberjj
Friend of Fast
posted April 13, 2010 11:05 AM
I noticed a couple mph when I stopped using the clutch to shift, plus it stopped the wheelying when shifting into 2nd.
kaw-rick
posted April 13, 2010 11:50 AM
Ive seen people sitting up b4 the finish line. Run it past where you think your supposed to stop and see what happens.
moses
posted April 13, 2010 12:03 PM
the r-77 pipe is the full header not a slip on. i was using the clutch . the only reason for the race fuel was the gas light came on and thats what they had. thats why i only put a half gallon in . it was the first time out on this bike. its alot more to handle than the 99 r1 i was riding. that was stock lengh and i went a 1.6 60ft on that so i know i will get better on the zx14.
posted April 13, 2010 12:18 PM
Where are you located? What were the air conditions?
gilberjj
Friend of Fast
posted April 13, 2010 12:37 PM
Himalaya drag strip: Elevation 15,765 ft.
It has a nice view
Wheelie
Old Man
posted April 13, 2010 12:50 PM
yep.
wee
SteddyTeddy
posted April 13, 2010 12:51 PM
That MPH seems about right for the ET you ran.
tnt
posted April 13, 2010 04:53 PM
Seat time ! That will get the mph up ! Work on your 60 ft and in the process you'll start building the mph! Best mod ever is that clutch hand!!!!!!
j-bird09
09 se
posted April 13, 2010 05:52 PM
isnt it hard on the clutch not to use the clutch also when you shift with out do you have to let off or not
09se flies out m14 bmc street pcv jeffo map 16t
dcjens
Wet side of Washington
posted April 13, 2010 06:39 PM
we're supposed to use a clutch? I use the starter and go..on the street. up or down
Black 06
Quarter Pounder
with Cheese
posted April 14, 2010 06:27 AM
not hard at all on the clutch...as a matter of fact, clutch don't care at all. It stays engaged.
If you are WFO, all you need to do is give the shifter some up pressure to preload it, and when you want to shift, simply lift off the throttle for a split second...bam, into the next gear. Faster than using your clutch, but nowhere near as fast as an airshifter.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
epd345
posted April 14, 2010 09:23 AM
Moses definetly get that thing a PC-III or PC-V. I run a full Yosh exhaust also and I got my commander from fuelmotousa.com. They are Yosh tuning center so they have dyno tested Yosh Exhaust on 14's so they can set you up with a specific inhouse custom map for your specific set up. They also offer free maps when you buy your PC from them. I bought my PC-III preloaded with a fly's in map from them and used that for over a year and it was great. When I removed my flies I just emailed them and they supplied their custom correct map for the fly's out and the bike runs excellent. In my experience they have been great to deal with and great customer service also.
j-bird09
09 se
posted April 14, 2010 02:24 PM
wow ok great had always wondered about that used to do it all the time when racing mx
moses
posted April 16, 2010 04:52 PM
i went to atco tonite only got 1 pass before the rain still 10.1 136 bogged off the line . i tryed to leave too hard i guess.7500 then almost dumping the clutch, still learning the bike. i picked up some sprockets today 16/44 and clutch springs and spacers from carpenters. im gonna try the sprocket in stages just the front for a while then add the rear i will look into a pcv chipped for my mods. im by no means trying to be a contender on the ama drag racing circuit. i would just like to see some mid 9 second passes. just reading all the stuff on the web i thought it would only take a couple passes
posted April 16, 2010 05:25 PM        Edited By: smokinZX14 on 17 Apr 2010 01:26
First off you don't need lower gears at stock wheel base .. Second you don't need the clutch spacers either ..
You are looking for quick fixes to go faster .. sorry there are no quick fixs ... You need seat time and that is all you need ... The way your bike is right now will run in the 9s no problem even with your 200+ pound frame .... Keep going to the track and the numbers will drop on there own ... P/S watch out for a little guy on a VMax , he is looking for new guys on zx14 to pick on so he can claim another zx14 kill ..
moses
posted April 17, 2010 05:20 AM
the sad truth is my bike is lowered with extentions. i only have 5 passes on it with a best 60ft of 1.67. alot of people told be for my 235 lb weight i need to change the gearing and the clutch springs will help the clutch last. i have seen a small guy on a new vmax i dont think it was his. hes was a real nice guy and owns a few r1s. i never ran the vmax but after the 60ft his r1 just walks around me.
posted April 17, 2010 07:18 AM        Edited By: smokinZX14 on 17 Apr 2010 15:19
You didn't say you had the bike longer ... Yes gears will help and so will the clutch spacers .. Still the best mod is seat time ... No getting around that fact .. You should be able to run mid to low nines with what you have now even at 235 pounds..
moses
posted April 17, 2010 06:24 PM
thanks smokin i will keep at and let you know. my first post says 6 over i ment in length
0.21900987625122 seconds processing time
