BIKELAND > FORUMS > ZX-14.com > Thread: Ti-Moly rear Sprockets NEW TOPIC NEW POLL POST REPLY
LAB3
posted April 16, 2010 04:34 PM
Found a site that custom makes Really hard steel rear sprockets................45 and larger.
Krause Racing...... google them and see all the different hard metal alloy steel sprockets they make. Expensive ..wish Driven made a 45 in steel.(50 bucks) called them, no more that large in steel.
Never used Krause before,.............anyone?? Or a different co. that makes steel rear
in 45 to 47 teeth. Trying taller rear tire 190-55-17............. PP2CT
Louis
epd345
posted April 16, 2010 06:30 PM
Im going the oppisite way Lab, I am going to try a 40 tooth on the rear with the stock up front to see what that does. Drive Systems Usa, 39.99 for a black steel 40 tooth from a zx12 which works with the Carrozzeria Cush drive.
LAB3
posted April 17, 2010 04:15 PM
All these Drag Racers and No one has used these steel rear sprockets. Look at the chain they have..........
68gts2
hobbies ( Beating you !!! )
posted April 17, 2010 04:22 PM
Louis check with Super Sprox USA and see if they have sdded more teeth to their line up. Aluminum center section and steel teeth. About 100 bucks with lifetime warranty and half the weight of steel. Its a win win.
LAB3
posted April 17, 2010 04:49 PM
Thanks, look at the chains on Krause Racing way stronger than the EKZZZ I just purchased.
Do not think my 14 needs it but I have never seen a chain that high of a rateing.
oilfieldtrash
Kawasaki enthusiast
posted April 17, 2010 04:54 PM        Edited By: oilfieldtrash on 18 Apr 2010 00:54
Now it's not going to be even close to fair. My stock sprocket vs your 45 tooth!
'07 white S.E. ZX-14 sold
LAB3
posted April 17, 2010 05:07 PM        Edited By: LAB3 on 18 Apr 2010 01:09
Hey I am 50 pouds heaver than you... sigh.
Man you 14 runs good, that was big fun the other day. Glad we did not get a
speeding ticket. I am going to try your map you just had made and see how mine does.
My new taller rear tire takes away about 1 tooth on the rear. When your chain stretches out
a 43 will bolt on the stock chain like mine is now. I will let you try the 43 when I install my new chain and 44 or 45 rear and new 190-55-17 PP2CT tires. Good meeting you Shane
next week we will race again. They sure are close :-) You will spank me with a 43.
Louis
0.26446485519409 seconds processing time
