BIKELAND > FORUMS > ZX-14.com > Thread: Superflow SF-240 Dynamometer... NEW TOPIC NEW POLL POST REPLY
BIG BLUE_ZX14
posted March 31, 2010 07:02 PM
is the type of dyno the local tuner has who has the best reputation for knowing what he is doing. As I know nothing of dyno's...if i have him do a dyno run is there anything peculiar to this type of dyno that I should be aware of? Is it better/worse than other types? Thanks in advance!
2007 Blue ZX14 Gone...
SLVR_BLT
Chicken Strips!
posted March 31, 2010 07:49 PM
Every dyno can be a liar depending on calibrations and settings. Even if every shop in the country had a DynoJet dyno they vary on calibrations and settings. Its only as accurate as the operator and calibrations.
LAB3
posted April 01, 2010 03:21 AM        Edited By: LAB3 on 1 Apr 2010 11:22
Super Flow Eddy Current Dyno has options a Dyno Jet use to not have.
A Eddy Current Dyno can hold a steady RPM's as it makes it easier to set
correct air box pressure, compaired to the common Dyno Jet that could only
make a complete run through the RPM range. Super Flow are a lot more $$ too.
What the tuners and exhaust co's Don't publish is the Data sheets that record
How much faster did the exhaust you were testing made it's power. If I remember
it was every 5 tenths of a second it will print O2,CO2, A/F, HP and Torque and
wheel speed.
0.2332329750061 seconds processing time
