BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy Bonneville ? NEW TOPIC NEW POLL POST REPLY
dogg24
posted March 30, 2010 11:38 AM
Muzzy Bonneville ?
Putting one on and a question about the setting for both +2 in the rear only and -1 in the front and +2 in the rear. I also know everyone says the bike is off by 8% already so thanks ahead of time for your help.
2012 ZX14R SE, Streetmeg, PCV
SixSixoh6
posted March 30, 2010 11:54 AM
i got the same gearing, set mine at 89%
dogg24
posted March 30, 2010 12:06 PM
Is that for the +2 only or -1/+2.
dogg24
posted March 30, 2010 12:09 PM
The directions had a formula for the correct setting but I just wanted to double check.
(New front size x STD front size/ new rear size x STD rear size) -1 x 100%
SixSixoh6
posted March 30, 2010 03:35 PM
that is for -1 +2. that formula can be a bit confusing. it says 91% for a -1 sprocket only. so 89% for -1 +2 sounds correct.
dogg24
posted March 30, 2010 05:31 PM
By the formula they use I get 84 for a +2 only and 85 for a -1/+2. Then you got the other 8% for what the bike is already off. So should I set it at 92 for +2 and 93 for -1/+2?
0.24874997138977 seconds processing time
