BIKELAND > FORUMS > ZX-14.com > Thread: Clutch Question NEW TOPIC NEW POLL POST REPLY
LeonidasZX14
posted March 26, 2010 08:20 PM
Clutch Question
Roughly a month ago I pulled my clutch to inspect it. Upon reinstalling my clutch I screwed up two things. First of all I did not install the largest fiber last and second of all I did not off set the last fiber in the hub. I have had a horrible past 3 trips out and either wheelie or bust the tire loose right off of the line. When I say wheelie instantly I mean that literally, like before the 60ft mark. My last two plates were warped when I took them out a while ago but I moved them further out in the hub and put the good ones further in. I strongly think that one of these clutch issues is my spinning/wheelie problem. I just put in a brand new clutch which should resolve my problems but my curiosity is killing me.
What are some thoughts??
09' ZX14
SixSixoh6
posted March 26, 2010 08:59 PM
Sounds like you got some discs applying too much pressure and its not meshing up correctly with your clutch release poiints. If I were you....I'd redo the whole thing from start to finish. Get rid of the warped discs..prob would solve the issue in itself right there.
Good luck!
posted March 27, 2010 06:21 AM
Not off setting the last fiber in the hub will not cause any problems .. I put mine togetther that way and never had a problem ..Not using the large fiber ? Humm i don't know about that ..
Quarter Pounder
with Cheese
posted March 27, 2010 07:05 AM
moving warped discs around in the pack will not do you any good either...stack height is stack height...only so much room in there and warped discs will be a problem no matter where you put them in the stack.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
LeonidasZX14
posted March 28, 2010 01:40 PM
Due to the overwhelming response I figured I would post my results with my new clutch. The old clutch WAS the problem. I took it to the track today and got 3 passes, the first two were a bust just do to the uncertainty of a new clutch but my 3rd pass a layed down a 1.377 60ft.
09' ZX14
dakota9498
posted March 28, 2010 01:48 PM
Damn nice short time. What gear are you running if you don't mind me asking?
2008 ZX14
posted March 28, 2010 01:53 PM
Would That would be your best 60ft so far??? That's gettin it done!
LeonidasZX14
posted March 28, 2010 01:54 PM
Yep,
I think that was my best ever. I know that my bike has a ton more also. I am going to go 3 times this upcoming week for more testing.
09' ZX14
LeonidasZX14
posted March 28, 2010 01:55 PM
16/41 but I am 130 lbs.
09' ZX14
1badzx12r
posted March 28, 2010 02:16 PM        Edited By: 1badzx12r on 28 Mar 2010 22:16
whats the rest of the run an 8.70 or a 5.60 or did the tire spin
dakota9498
posted March 28, 2010 02:17 PM
Yeah, I am stock right now, I think I am going to go with 16/43, because I weigh around 155. Thanks for the help.
2008 ZX14
LeonidasZX14
posted March 28, 2010 02:24 PM
8.79 at 159 my 1/8th was way off due to a wheelie.
09' ZX14
CraigChrist
BAWLS
posted March 28, 2010 02:44 PM
so how big of a shot are you spraying to run 159 again?
60ft-------1.42
1/8th------5.97
mph-------119
LeonidasZX14
posted March 28, 2010 02:58 PM
Just a small one.
09' ZX14
CraigChrist
BAWLS
posted March 28, 2010 04:28 PM
silly chad
60ft-------1.42
1/8th------5.97
mph-------119
SteddyTeddy
posted March 29, 2010 06:17 AM
Did you make it any rounds? I spun bad off the line and got put out first round. Loaded up and headed out before the rain hit.
1badvespa1400cc
power junkie
posted March 29, 2010 06:42 AM
I thought you looked light when we met sun.(lol)bike was setup nice and ran nice also good riding!!!!
Just another foeteen!!!!!
LeonidasZX14
posted March 29, 2010 01:40 PM
No, I red lit first round. Way before the rain.
09' ZX14
chadszx14
posted March 29, 2010 06:07 PM
iv changed clutchs ion my bike plenty of times and u lost me about the one big fiber....i know theres one small one and it goes in first but i thought all the others were the same size...please correct me if im wrong
06 14, stertched 9" over stock,dyno jet pc3, star racing custom map,16-44 sprockets, 7" fold out touch screen, GPS, full muzzy exhaust
madnessracing
Vmax and Busa Beater
posted March 29, 2010 06:23 PM
How stretched is your bike leonidas?
Shorty's Performance
Team Madness Racing
CraigChrist
BAWLS
posted March 29, 2010 06:24 PM
that is correct. the problem was putting warped fibers back in.
60ft-------1.42
1/8th------5.97
mph-------119
chadszx14
posted March 30, 2010 08:26 AM
im sure u ment 2 say steals right.
ninjaboy311
posted March 30, 2010 10:01 AM
You are wrong. The outter most fiber is bigger than the rest, while the inner most fiber is smaller than the rest.
LeonidasZX14
posted March 30, 2010 05:07 PM
I did not know that either but I got my clutch pack from Muzzys and there was 3 sized fibers. The smallest goes closest to the motor. The others go in the middle and there is one fiber that has larger pads on it that goes in last. I read my owners manual and it specifically says to put the larger fiber last.
09' ZX14
LeonidasZX14
posted March 30, 2010 05:09 PM
My bike is 65"
09' ZX14
0.31172204017639 seconds processing time
