BIKELAND > FORUMS > ZX-14.com > Thread: Suspension settings NEW TOPIC NEW POLL POST REPLY
kawboy81
Busa Eater
posted March 26, 2010 06:52 AM
Suspension settings
Just wondering if any of u suspension guru's could tell me where I need to be at on my settings for an aggresive street/strip setup. I'm 198lbs. Thanks
07 LE bolt on bike
Quarter Pounder
with Cheese
posted March 26, 2010 06:58 AM        Edited By: Quarter Pounder on 26 Mar 2010 14:58
street and strip are completely different settings and no where near each other
First thing you need to do for the street is set your sag on both ends. Once you have the correct spring preload set, then you need to find that happy medium in rebound, compression damping.
Start with stock settings on those and soften one of them quite a bit to see how it affects the ride...then go a lot stiffer on that setting to see how it affects it....dial it in to your preference. Do the same for both rebound and compression on both ends.
BUT, key is only make an adjustment on ONE thing at a time...and understand how it affects the bikes handling.
For the dragstrip its a bit easier....for the rear, set the rear spring as soft as you can without bottoming it out on the inner fender....start with full soft compression and full hard on rebound on the rear shock. Front does not matter that much especially if you are strapping it.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
kawasakijockey
posted March 26, 2010 07:10 AM
At 198lbs, if you are stetched 6+ inches over, you will have to max the spring stiffness and go full hard on both screws. QP's settings are correct for swb and 160lb guys though.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Quarter Pounder
with Cheese
posted March 26, 2010 07:22 AM
it was assumed that you would have correct spring rates (hence setting the correct sag first). Other than that...it applies to any rider, any weight.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
kawboy81
Busa Eater
posted March 26, 2010 08:49 AM
Ok. I've never fooled with supsension on my bikes ever. Compression and rebound are whch two? Also u said soft compression, hard rebound.... Jockey said full hard on both. I am stretched about 6 over front will be strapped. Thanks
07 LE bolt on bike
Quarter Pounder
with Cheese
posted March 26, 2010 09:07 AM
need to start with reading your owners manual
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
kawasakijockey
posted March 26, 2010 09:11 AM
Compression screw is on top of shock and rebound is on bottom.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawasakijockey
posted March 26, 2010 09:27 AM
Jon, you have to figure that the spring will rightly let the bike squat only so far but the compression valving dictates how slowly it squats. A bike needs to be in squating stroke as long as possible, not quicker squatting. A soft compression does not apply to all bikes, lengths, rider weights, and horsepower. A bike with too soft compression will squat until the spring stops it or bottoms out then it will spin the tire or wheelie.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kawboy81
Busa Eater
posted March 26, 2010 09:42 AM
I agree. I bought it used and therefore didn't have one. Guess Ima have to scoop one up. Buy like I said I've never fooled with it until now when traction has become a issue.
07 LE bolt on bike
Quarter Pounder
with Cheese
posted March 26, 2010 10:13 AM
I was in the same boat when I bought mine...no manual. I bought one of them shop manuals on CD off evilbay and it has proven well worth the coin I spent. Order one up and it'll have everything you need and then some.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
07zx14blk
ZX6R, ZX9R,ZX12R,ZX14
posted March 26, 2010 11:28 AM
You can download the manual:
http://rapidshare.com/files/218324555/ZX14_Manual_and_Fiche.pdf
kawboy81
Busa Eater
posted March 26, 2010 01:16 PM
Thanks for the manual bro.....
07 LE bolt on bike
THEMADKAW
posted March 26, 2010 03:45 PM        Edited By: THEMADKAW on 26 Mar 2010 23:47
here's something that may help too.
http://www.onthethrottle.com/content/view/206/40/
http://www.onthethrottle.com/content/view/208/40/
CraigChrist
BAWLS
posted March 26, 2010 03:53 PM
Whatever you do, don't put a stiffer spring on a stock shock. It doesn't work at all and you'll never run good times that way...
60ft-------1.42
1/8th------5.97
mph-------119
0.23976993560791 seconds processing time
