BIKELAND > FORUMS > ZX-14.com > Thread: ••••)> 16t or 2 up in the rear...--- ...rpm/highway speeds ??? NEW TOPIC NEW POLL POST REPLY
TampaGunSlinger
posted March 25, 2010 05:40 PM        Edited By: TampaGunSlinger on 26 Mar 2010 01:40
i have stock gearing now, i like cruising at lower rpms on the high way, , i take long trips sometimes. at 70mph i think i'm somewhere around 4k, at 90 i'm close to 5k.. how much of difference when cruising at those speeds will the rpms be with a 16t front sprocket or +2 rear.. i want to do the 16t front cause this way i can keep my stock chain and the rear wheel will be moved back father then if i tried to get a 2 up rear sprocket on the stock chain (i.e. little bit longer wheel base), i like the idea of going with a larger rear sprocket cause i can put it on my self and i know it wont be to much rpm's. can you put a +2 rear sprocket on a stock chain.. has anyone done it - i have almost 3k miles on my bike its an 06
ZX14Mike
posted March 25, 2010 06:23 PM
My estimates would be 300 additional RPM for a 43 tooth rear and just under 400 for a 16 tooth...............if you have over 2000 miles on the bike there should be enough chain stretch to run a 43 tooth rear.................if most of your riding is highway then go with a 43 but keep in mind I run 16/42 and dont find it buzzy on the highway at all even at 90, plus it keeps your wheelbase essentially the same as stock and is a GREAT all purpose ratio good for the highway and the dragstrip.
LLcooljebb
Upgrade I Must
posted March 25, 2010 07:12 PM
i run a 17/45, cruising at 65 my rpm is 3900-4000 (speedohealer/gps adjusted). instant mpg still reads over 30.
ratios:
16/42=2.63
17/45=2.65
16/43=2.69
feels high at first, but you get used to it...just crack the throttle...wow!
"no time to be void or save up on life
you got to spend it all.."
TampaGunSlinger
posted March 25, 2010 07:21 PM
i'm leaning to do +2 rear sprocket, if i can fit the chain on it i will be happy with that... i think i will buy a vortex sprocket maybe a red one or whatever one matches my 06 passion red bike
CajunBoyz
posted March 26, 2010 03:05 AM
Go with +2 on the rear, & add a few chain links tot bring it back to normal or longer wheel base
posted March 26, 2010 03:13 AM
http://www.gearingcommander.com
posted March 26, 2010 03:32 AM
I don't think you would tell a whole lot of difference between +1 and -2. frog sprocket would be cheaper, rear sprocket would make the bike look better. How many miles are on your chain?
68gts2
hobbies ( Beating you !!! )
posted March 26, 2010 04:01 AM
The + 2 is going to make your wheelbase as short as the adjusters will allow without adding some links. The gear combined with the short wheelbase makes the front tire levatate magicly. The sprocket people told me the +2 provides a smoother torque band than a -1 front setup.it seems to be steep the 1st ride or two,but after a couple of rides you realize how much better the bike is everywhere. Taking off in 1st gear is much easier on the clutch as you don't have to be going 20 mph to realease it fully. I ride hwy a bunch and run 70 to 80 mph with ease. Roll-ons are also greatly improved with this gearing combo. Lab3 can attest to its improvement over a stock geared bike as he runs a +2 combo as well. Try it,you will like it. I run a Super Sprox hybrid sprocket,steel teeth aluminum center. It offers light weight and twice the life of just the aluminum sprocket. My 02 cents worth.
LAB3
posted March 26, 2010 08:47 AM
What he said :-)
Louis
TampaGunSlinger
posted March 26, 2010 01:13 PM        Edited By: TampaGunSlinger on 26 Mar 2010 21:14
i went to cycle gear today and bought a new vortec 43tooth sprocket i got in the harden black.. i'm thinking about trying out the Michelin sport 200/50/17 rear tire has anyone had any problems with the 200mm michelin tire.. i have heard it is not a true 200mm and is made for the zx14 and other big bore bikes so it will fit on the rim pretty good
the sprocket will be in next week some time, they charged me 59 bucks for it... and my chain has 2,800 miles on it today
posted March 26, 2010 01:26 PM
A 200 tire will turn your 43T sprocket into a 42.5T. It's taller than a 190, and affects your overall gearing.
kawboy81
Busa Eater
posted March 26, 2010 01:35 PM
wil a 200 tire fit with no rubbing or mods?
07 LE bolt on bike
TampaGunSlinger
posted March 26, 2010 02:44 PM        Edited By: TampaGunSlinger on 26 Mar 2010 22:45
are you sure cause the its a 200/50/17 and i think the stock tire is 190/55/17
and i saw a pic of a guy with the Michelin sport 200mm tire on a 14 with no problems
posted March 26, 2010 03:00 PM        Edited By: Shane661 on 26 Mar 2010 23:02
The stock tire is a 190/50, which is usually much shorter (when installed) than a 200/50. The taller tire does affect gearing, but you probably won't notice it much.
TampaGunSlinger
posted March 26, 2010 04:01 PM
well that might just be what i needed to do, i'm trying to find out what kind of milage i'm going to get out of this sport HPX 200mm tire, for the price i hope its at least 6k miles.
0.25668001174927 seconds processing time
