BIKELAND > FORUMS > ZX-14.com > Thread: PING KIKONZX14 NEW TOPIC NEW POLL POST REPLY
epd345
posted March 19, 2010 07:57 PM
PING KIKONZX14
David here is a pic of the bracket for the right side of the Hugger you asked for. Hope this helps.
posted March 20, 2010 06:37 AM
That looks like some ghetto stuff on my bike!
epd345
posted March 25, 2010 01:14 PM
Kikon let me know if you got this.
KikonZX14
Novice
posted April 05, 2010 09:33 AM
Thanks Joe, I've missed this thread.
Hugs,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
SLVR_BLT
Chicken Strips!
posted April 16, 2010 05:49 PM
Whats that big orange wire for?
epd345
posted April 16, 2010 06:22 PM
That would be a RED rear brake line.....spiegler
posted April 16, 2010 06:53 PM
ping pong kikon...
SLVR_BLT
Chicken Strips!
posted April 16, 2010 07:03 PM
Ahh i see, i didn't see any steel braids so it kinda fooled me into thinking its something else.
epd345
posted April 18, 2010 06:32 PM
The braids are covered up for you in the protective covering that you pick the color of. I guess if I picked clear protective covering we would see steel braids.........Yappers we would
SLVR_BLT
Chicken Strips!
posted April 18, 2010 07:05 PM
oh interesting, I thought their red ones were transparent red.
KikonZX14
Novice
posted April 19, 2010 10:10 AM
Hiya Guys, I just got the bracket from Bestem personnel. They (Daz & Rod) were very kind in order to help me with this issue, and they sent me the bracket without any further cost.
Now THAT'S what I call Service of Excellence!!!
Thanks to all of you and specially EPD345 for the help
Hugs All,
David
epd345
posted April 19, 2010 07:41 PM
David Glad I could assist, help and great advice is strong on the forum and thats why I like it so much!!
SLVR_BLT
Chicken Strips!
posted April 19, 2010 10:06 PM
I just bought a rear hugger off Bestem, he says the right side hardware is included so we'll see how this will go once i get it here.
Hellmutt
posted April 20, 2010 03:49 AM
EPD345, is there signs of the line rubbing that bolt head where you'd ziptied the line? Just wondering since I had Brembo setup on my last bike and the rear line wore against the swingarm clamp after it had backed off a bit -- just don't want to see anyone have problems from brake fluid eventually ending up on the rear tire.......personally, I'd use a padded P-clamp in the bolt hole you ziptied the line thru - just a suggestion
epd345
posted April 20, 2010 12:21 PM
its rubbing but not worn through, where can i get the padded P-clamp. Thanks
KikonZX14
Novice
posted April 21, 2010 11:11 AM
Hiya Guys, here goes a small tutorial about the installation of a Bestem Rear Hugger in a ZX14:
- Product: Kawasaki ZX14 Rear Hugger by Bestem (USA)
1.- Exhausts must be taken off the bike:
2.- Dismount the chain cover (loosen up the two philliphs head bolts and the rear plastic tab):
3.- Install the left Hugger side using the same original threaded holes and the two phillips head bolts (the Hugger does not come with rear tab system as the original chain cover):
4.- Then on the right side you use the supplied bracket which goes bolted in the same place as the rear brake guide. Watchout! as you need to use a longer bolt (provided with the bracket). The original bolt, I've used it to secure the Hugger to the other end of the bracket (using a self locking nut, provided with the bracket).
5.- You re-install the exhausts and VOILÁ! A distinctive touch for the ZX14 ;D
Hugs,
David
SLVR_BLT
Chicken Strips!
posted April 21, 2010 12:02 PM
Looks cool, my only concern is if there is enough clearance above it that the hugger wont slam into the under tray when suspension is under full stroke.
Hellmutt
posted April 21, 2010 12:27 PM
Most auto parts stores or even hardware stores should have something that would work --
0.42972302436829 seconds processing time
