BIKELAND > FORUMS > ZX-14.com > Thread: New PCV need help NEW TOPIC NEW POLL POST REPLY
zx14r09se
posted March 04, 2010 05:58 PM
New PCV need help
Hey cool!just got my new pcv for my 09 se 14 ... the problem is it dosent say to mutch on the wirering for the 14 man..... do i need to find any wire for temp , speed, and crank and for the shifter is it only a grounded loop on the 2 shifter pin or it needs somting else????and they only have 5 maps for the 14 09 models at power commander site nothing with the flies out that sucks.... any sugestion ??? thanks
live to ride...but only on a 14
  Ignore this member    Click here to visit zx14r09se's homepage.
wrongway
posted March 04, 2010 07:51 PM
you can use speed if you want a map per gear. quick shift is just a momentary contact. . you can use PC3 maps with the conversion tool on the PCV software, but the midrange stuff wont be correct.. With the autotune you could build a map, but a custom dynotune maybe better.
Roy
zx14r09se
posted March 05, 2010 03:09 AM
quick shift is just a momentary contact...is it a ground contact.. lets say i plug it to the horn button to do a ground contact will it work....
and for the map im not looking for the world record land speed just a good map to richen the the map where its lean when the flies are out.
dont know mutch about pcv and the map thing but im working on it
my plan is ...quickshifter,the button for the 2 map stuff(1 for gas economie and one for racing) and autotune(but ill wait t ill i get $$$$$)the muzzy m14 and the pcv is walet breaker.
and for the speed wire is there a shem to guide me a bite
0.29575490951538 seconds processing time
