BIKELAND > FORUMS > ZX-14.com > Thread: airshifter mounting NEW TOPIC NEW POLL POST REPLY
fbmbks
posted March 04, 2010 09:13 AM
airshifter mounting
alright just got an airshifter for the 14 and was wondering if any of you made your own mounts, this is what one person did " I use a 1/4" by 20 tap to thread the inside of that bolt. Then go to Lowes and get either a 2.5" or 3" allen head shoulder bolt to go in it and a couple of nuts. All it takes then is a spacer so you dont bind the air ram (I use old sockets, you can paint them to hide them)"
looking to see if any of you have done similar and have some feedback and suggestions
LeonidasZX14
posted March 04, 2010 09:27 AM
Sounds similar to my setup except I used metal brake line as the spacer. It covers the threaded rod very nice and is already black.
09' ZX14
fbmbks
posted March 04, 2010 09:31 AM
do you have any pics? so the general idea is to tap the inside of the bolt so you can screw the new on into it, us a nut to keep it from turning back out and use the brake line to keep the shifter from binding? sounds pretty simple to me
gilberjj
Friend of Fast
posted March 04, 2010 09:37 AM
Orient Express sells one for $40. That's the cheapest I've seen. Seems pretty easy to build though.
LeonidasZX14
posted March 04, 2010 01:58 PM
You hit it right on the head. Only thing I left out was a washer to keep the brake line from sliding through the airshifter mount.
09' ZX14
posted March 04, 2010 02:02 PM
I used bigger nuts that would slide up and down the bolt. Same purpose as the brake line
LeonidasZX14
posted March 04, 2010 02:04 PM
Also do not overtighten the bolt the shifter needs a bit of free play or it will bind.
09' ZX14
fbmbks
posted March 04, 2010 02:11 PM        Edited By: fbmbks on 4 Mar 2010 22:12
thanks appreciate it, seems pretty simple and a lot better then paying for a muzzy kit
fbmbks
posted March 04, 2010 06:35 PM
alright now whats the best way to mount the bottom, can you buy just the piece that screws to the shifter??
Black22
posted March 04, 2010 07:25 PM
The ram should come with a clevis. You just drill a hole thru the shifter and file it down a little to make it flat. Make sure you dont run out of travel for the ram, it must not bottom out either direction. Usually the hole will be just past half way of the shifter.
Amsoil
Shift FX biperformance.ca
Go-Pro Hero Cameras
fbmbks
posted March 04, 2010 08:39 PM
alright thanks, bought one from Spencer cycle should be here in a cpl days
0.21742105484009 seconds processing time
