BIKELAND > FORUMS > ZX-14.com > Thread: What does denotation or (engine ping) sound like on a zx14? (48-50 shot dry) NEW TOPIC NEW POLL POST REPLY
BLK ICE
posted January 28, 2010 05:45 PM
I’m thinking of adding a spray bar 50 dry shot without pulling timing on BP 93 pump gas with a progressive controller . Has anyone tried this combo? Will it works? What does denotation or (engine ping) sound like on a zx14?
02zx12rbob
posted January 28, 2010 10:04 PM
Not sure about the ping thing, but thats about the same set up I'm gonna try.
SixSixoh6
posted January 28, 2010 11:26 PM
i dont think anyone has been gutsy enough to find out without blowin ish up. just get a muzzy plate and take it back -2 degrees
posted January 29, 2010 08:32 AM        Edited By: Shane661 on 29 Jan 2010 16:32
The sound of detonation on a 50 shot is much like the sound of your wallet opening.
I would play it safe and pull a little timing.
LAB3
posted January 29, 2010 08:54 AM
Good one LMAO but Good advise.
BLK ICE
posted January 29, 2010 12:24 PM
Good point, but I can't find a EFIR for 07 zx14(I have a nos mini, PCIII, and Hub with Map switch), what would you guys use to pull timing?
06redzx14
posted January 29, 2010 12:26 PM
why not just run race gas? they should sell 104 at your track
BLK ICE
posted January 29, 2010 12:36 PM        Edited By: BLK ICE on 29 Jan 2010 20:37
I'm tring to stop buying high priced gas(MR9 $134 5gal). So I can ride the bike to the track and not have to drain the tank every night after racing.
BLK ICE
posted January 29, 2010 12:42 PM
Will the muzzy plate-2degrees slow me down on motor?
Compton
posted January 29, 2010 12:48 PM
get the power commander ignition module. you have the hub, just make a spray map and a nitrous map. you can adjust timing and do a lot of other neat tricks with it.
b.w.
zxbob
posted January 29, 2010 03:18 PM
Most of the time (and your on the botton) if you hear it . . . . its too late !
Bob
14nooby
posted January 29, 2010 09:16 PM
Me just peeking in on this not knowing much about NOS. Why would you try and cut corners on fuel to save a couple bucks? A blown engine will cost you much more. High octane fuel costs no where near MR9 maybe 15 bucks a gallon or so. Do you plan on running a 5lb NOS bottle? You will probably only get 2 passes on a 2 lb bottle and besides when you blow it up running pump gas it is going to suck balls pushing it home.
BLK ICE
posted January 29, 2010 10:03 PM
Good advice here! That's why I like this site so much.
01smokes
posted January 29, 2010 10:07 PM        Edited By: 01smokes on 30 Jan 2010 06:07
101 is like 7-10 bucks a gallon and would be good for it, my bike was tuned with 101 on a 50 shot and i never had any problems i put about 25-30 pounds of nitrous to it in a years time, now its going turbo same stock motor not even springs yet knock on wood
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
gilberjj
Friend of Fast
posted January 29, 2010 11:06 PM
All good info. I don't have much to contribute, but I'm lurking in the shadows.
SixSixoh6
posted January 29, 2010 11:14 PM
I honestly don't think it will slow you down much if you pulled -2 degrees. If I remember it right it was -1 degree for every 40-50 hp shot of nitrous. -2 would just be added insurance. Would highly recommend some dyno time if you're going to spray 50hp.
Just my 2 abe lincolns.
jarhead
posted January 30, 2010 12:10 PM
Guys I think it is good to error on the side of caution, that being said, I have been spraying a 50 shot since the bike was new in Sept. of 06. I have always run premium pump gas and let her eat. There is no need to pull timing until you cross the 50hp threshold. The most important thing is a good map to ensure you are getting the proper amount of fuel. I finally pulled the head just due to the amount of nos passed on the bike and everything looked fantastic. I run my spray through a Schnitz two knob controller and bring it in slowly so I don't hit anything hard inside the motor. I put springs in the head and put it back together. Ready for a few more years of flogging. These things are engineering marvels!
gilberjj
Friend of Fast
posted January 30, 2010 12:15 PM
That is great news to hear jarhead!
jarhead
posted January 30, 2010 12:20 PM
BTW, if you guys are considering spraying, one thing to keep in mind is this. If you spin and hit the rev-limiter, close the throttle, if your opponent is even decent you lost anyway. This is where guys get in trouble with spitting shims.
posted January 30, 2010 12:55 PM        Edited By: Shane661 on 30 Jan 2010 21:03
Well, there are exceptions to every rule I guess.
For me it wouldn't be worth risking. I have too much time and money invested in my bike. I think most would agree that it is not a good idea to spray 50 on pump gas without pulling timing.
Just curious, how long do you stay on the button? What is your a/f? How much change in rwhp when you are spraying? How slow are you bringing it in with the 2-dial?
Track results? Size of your nitrous bottle, bottle pressure, pressure regulation?
LAB3
posted January 30, 2010 01:04 PM
+1 looking at a small shot too.
INTIMIDA2OR
RED rider!
posted January 30, 2010 01:13 PM
Bob
+1! Once it starts there's no stopping it .
'06 Passion Red ZX-14
*Lee*
01smokes
posted January 30, 2010 01:16 PM
When i would spray my bike with the 40-50 shot i would try to stay out of 6th gear so i would do 1-5th gear pulls on the button gearing was 16/44, my AFRs were set at 11.8 on 101 with the 50 shot it made like 47hp over my motor did and the 40 shot made right at 39hp
posted January 30, 2010 01:28 PM
Did you have a spray bar? How many jets, location?
01smokes
posted January 30, 2010 01:49 PM
No spray bar on my bike, i wanted to put one on but never got around to it. i had 2 nozzles going in to the inspection plates they were crossing each other, and there was 1 jet at the solenoid
This is a pic of the graph on the 40 shot .036 jet
0.22218894958496 seconds processing time
