BIKELAND > FORUMS > ZX-14.com > Thread: Sequential firing NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted January 27, 2010 11:48 PM
Sequential firing
Is the 14 sequential firing??
What does it mean?
I love my bike but dont know much mechanicaly!
Thanks Doug "clueless fool"
Doug Mackay Australia
Flame On
Fuel Air & Spark
posted January 28, 2010 12:26 AM        Edited By: Flame On on 28 Jan 2010 08:44
following in a sequence
If that's the trick question I would say yes
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted January 28, 2010 12:41 AM
Well the injectors fire in sequence as does the ignition.
The 14 fires sequentially . I guess you could call it sequential firing.
'06 Passion Red ZX-14
*Lee*
BobC
posted January 28, 2010 01:10 AM        Edited By: BobC on 28 Jan 2010 09:37
........and the sequence is......
(cue drum roll)
1 - 2 - 4 - 3 numbering from the left.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
speedgene
posted January 28, 2010 06:56 AM        Edited By: speedgene on 28 Jan 2010 14:57
Another point about 'Sequence fire,' means it fires the plug once. Old style 'multi-fire' electronic ignitions would mimic a set of points which used to fire twice [second spark was on the exhaust stroke].
Cam position sensor is a way of telling the ECU what cylinder (in sequence) is about to fire next once you turned the key off.
E-tard
INTIMIDA2OR
RED rider!
posted January 28, 2010 10:59 AM
Cool!
Wait .... Why can I understand this post!? Am I the only one ?
*Lee*
BIGZXDADDY
posted January 28, 2010 11:36 AM
the only ignition systems that don't fire in sequence are "waste spark systems" where one coil fires two plugs at the same time but only ignites one of the cylinders at a time,hence the name. sequential fire is a fuel injection term and it means the fuel injector fires once during four strokes delivering enough fuel for combustion at once. previous systems were called "gang bang" and all injectors were fired at once on every stroke but delivered 25% of the fuel. fuel builds up in the intake port so that when the intake stroke comes around and the valve opens there is enough fuel. most sequential systems will revert if the cam signal is lost allowing the vehicle to still be driven and usually the only sign besides the check engine light is worse fuel economy
"never drive faster than you can see, besides it's all in the reflexes"
Douglas Home
thanks for the info guys.
posted January 28, 2010 01:35 PM
is the injection also sequential... or batch fire?
speedgene
posted January 29, 2010 01:29 PM
There are individual maps for sequential. Note that each injector has it's own intake suck to the IAP sensor. One compression suck on that IAP will tell the ECU the pulse suck was not hard, so this one will receive said proportion off that voltage signal.
Batch fire is when you keep spraying more than one cylinder bank [in series] say.
"Brief definitions:
Batch-fire: Injectors are wired together in pairs (“batches”) and triggered in pairs (i.e. Cylinders
1&4 together and Cylinders 2&3 together).
Sequential: Each injector is wired independently with a unique ground, and triggered
independently."
E-tard
INTIMIDA2OR
RED rider!
posted January 30, 2010 12:20 AM
*Lee*
Douglas Home
posted January 30, 2010 12:59 AM
Great info guys, trouble is everything I discover leads to many more areas of ignorance!!!
INTIMIDA2OR
RED rider!
posted January 30, 2010 03:45 PM
No worries! Dumb questions are supposed to make one smarter. On the other hand dumb answers has the possibility of making everyone who reads it that much more retarded for having read it lol!
*Lee*
0.37872886657715 seconds processing time
